Crank Pulley Bolt?
Old 11-13-2009, 10:30 AM
  #41
KN_TL's Avatar
With the pulley tool, it's really an easy thing to do.
You could always take a road trip to CT and give Josh the job.
Old 11-13-2009, 01:54 PM
  #42
Freshjive360's Avatar
Where would I obtain this "pulley tool?" Are you referring to the breaker bar?
Old 11-13-2009, 03:30 PM
  #43
KN_TL's Avatar
http://www.youtube.com/watch?v=RE-pzP8g_x4
Old 11-13-2009, 04:37 PM
  #44
Former Sponsor
Excelerate's Avatar
Search on Amazon for Honda crank pulley tool.
Old 11-13-2009, 05:21 PM
  #45
Appreciate the help guys!
Old 11-13-2009, 05:45 PM
  #46
173rd Airborne!
ACE32TL's Avatar
Originally Posted by pohljm
Here is how you do it............ Get your socket and breaker bar and jack the car up slightly, place the wrench on the bolt with the handle in the 4 o'clock position. Lower the car until the wrench handle is in contact with the ground still in the 4-5 o'clock position. Go into the car and tap the ignition switch twice and your done. Sounds a little scary , but it works flawlessly. Oh and yes this is how I did it on my own vehicle!
installed my UR pulley today, this worked like a charm. TKS
Old 11-14-2009, 09:03 AM
  #47
Real Cars Have 3 Pedals
ACU-RATE's Avatar
I also CO-SIGN this method....
I got the bolt loose in less than a Minute
Old 11-14-2009, 10:44 AM
  #48
BMT62688's Avatar
What size socket do you use for the bolt
Old 11-14-2009, 12:31 PM
  #49
Tripnbeats's Avatar
on the 6mt..... theres another procedure.... before doing anything like releasing the drive belt.... put the car in 1st foot on the brakes.....dont pump them just press down once really hard hold it there and have someone crank the bolt off....ive done it like that a few times but it doesnt always work....the blip works all the time lol
Old 11-14-2009, 03:42 PM
  #50
BMT62688's Avatar
Well I just put my ur pulley on and it took me a half an hour I just did the blip method to lossen the bolt and it came right off with one crank
Old 11-14-2009, 06:48 PM
  #51
AZ Community Team
Bearcat94's Avatar
Received 7,770 Likes on 4,341 Posts
I'm really skeptical of the "Blip Method" on the '07/'08's with "one touch start". Don't think the car will "blip" once, but several times.
Old 11-14-2009, 10:07 PM
  #52
Everyone that has done this mod: when re-tightening the crank pulley bolt, how hard did you find it to torque the bolt to factory spec? Any tips/tricks?
Old 11-15-2009, 11:01 AM
  #53
Tripnbeats's Avatar
u tighten it to 80lbs i believe and then crank it a quarter turn more..... my mechanic says just crank the shit out of it.....most people cant turn the bolt to a full 160lbs anyway so between 130-160 is ok
Old 11-15-2009, 04:35 PM
  #54
BMT62688's Avatar
well im not sure about your year but for mine which is an 05 i just went in the fuse panel in the drivers side kick panel and took out the fuel pump fuse which was the middle row 4th from the back its was a 15 amp i cranked the car to make sure it wouldnt start then i went ahead and put my socket and breaker bar on got back in the car gave it one crank and it was off
acuratl26
04-23-2020 07:30 PM
tsx_boy
12-13-2019 08:33 PM
ROSSARONIE
09-22-2015 11:46 AM
Quick Reply: Crank Pulley Bolt?
