Computer Reset for CAI Install???
Old May 1, 2006 | 08:03 AM
Acura Jeff's Avatar
Just installed a new K&N Typhoon cold air intake.
Do I need to remove one of the battery cables for a half hour to re-set the computer?
Old May 1, 2006 | 08:12 AM
rbf351's Avatar
Registered User
if the install was anything like the AEM install then you would have removed the battery from the car during install
Old May 1, 2006 | 08:42 AM
tzakiel's Avatar
Cold Racketeer
For me, after I had my AEM intake installed, my dash had an emission check light on. So, I disconnected the battery for a while and then put it back on. The light was then off again.
Some have said that if you reset your computer this way it can also help your car re-adjust to your new setup... don't know how true it is but it can't hurt, right?
Old May 1, 2006 | 09:00 AM
subinf's Avatar
One on the right for me
I disconnected the battery for a little while...that seemed to do the trick
BustedJack's Avatar
The Boss
you DO NOT have to reset any ECU. The AEM intake or any intake installation requires you to unhook the battery terminal and it will automatically reset everything.
Old May 1, 2006 | 09:15 AM
HEK's Avatar
HEK
Team Nighthawk Mambo King
what he said...but check your lines, maybe you missed one and the check engine light came on for that reason....
Old May 1, 2006 | 10:49 AM
Acura Jeff's Avatar
No check engine light problems after the installation.
Just inquiring if the battery needs to be disconnected to reset the computer. Not sure if it was done during the install since I paid the Acura tech $20 to install the CAI for me on his time.
Old May 1, 2006 | 11:40 AM
lifetimeofwar's Avatar
JDM Laser Fogs!
So after you install the AEM (or w/e you have) you have to disconnect either batter wire for a lill bit, then reconnect it . turn on your car and your on your way? I dont understand how this resets your ECU
Old May 1, 2006 | 12:04 PM
lembowski's Avatar
Trucki!!
Hum......I didn't have to take the battery out with my install, nor did I unhook the battery. After the install I had the a check engine light flash on after I romped it coming out of my parking lot, but it went away after 10 seconds and has not come back. Did the ecu automatically update itself? Or does it still think I am running with the stock intake?
Old May 1, 2006 | 01:53 PM
BustedJack's Avatar
The Boss
When you disconnect the battery, your entire car loses power (obviously). Upon reconnection of the battery, the vehicle regain power and automatically resets everything. It'll ask you for the navigation code + audio code and resets the rest. The computer will relearn how you drive, how you accelerate, etc., The ECU learns, it's not dumb.
If you did not disconnect the battery during the installation, it will "likely" trigger a "CHECK ENGINE" light, but not 100%. In lemboski's case, the light did not stay on but to many it will. It's not a big deal to disconnect the battery prior to installation and reconnect them back after the installation, so why not do it to avoid headaches...
Old May 1, 2006 | 04:08 PM
lembowski's Avatar
Trucki!!
When I did mine I didn't see it in the instructions that I had to do it. It has been two months since the mod. Should I un-hook the battery now to reset the ECU or am I fine since the check engine light does show?
Old May 1, 2006 | 10:52 PM
JDM Laser Fogs!
Thanks for the info. Stupid question... It's true that when you disconnect the battery your entire car has no power, but (and this is the stupid part) isnt there no power running through the car when the car is off? So what im getting at is when the car is off and the ecu is not "running" how does disconnecting the batter effect the ecu?
And upon reconnection of the battery (after AEM CAI is installed) you turn on your car and the ecu recognizes that there is a new intake? Im just not getting it. I dont understand the fact that your car is off your ecu is off there is no power to the ecu, then all of a sudden (as soon as you reconect the battery) the ecu resets the settings.
I will deff. do a search, and I do not mean to bash your information because I have very minimal experience with ECU's settings, resetting...etc.)
Old May 2, 2006 | 01:59 AM
clausda0's Avatar
you know how when you plug your computer back in, after being uplugged, you can hear fans wind a little bit from recieving power? I believe having the battery connected keeps the power connected to the ECU, but just not powering it on. just thinking back to physics 2.
rockyboy
Aug 4, 2024 10:35 AM
Feb 25, 2020 09:57 AM
95legend6speed
Sep 21, 2015 06:40 PM
TxRzrBk
Sep 17, 2015 01:07 PM
vbgregg
Sep 11, 2015 05:38 PM
