comptech supercharger problem
Old Mar 1, 2007 | 12:40 AM
mmcv6's Avatar
313.4WHP& 284.6TQ
Hi. I had a comptech supercharger installed in my 2006 acura tl auto. The shop I got installed have done several kits of comptech two of the tl on the accord etc. Problem is my AFR is to lean. I put it on the dyno with the wideband AFR and it was to lean to get a base line. I was in the 17s... Hondata came to do a reflash for me, and he changed out the acm same thing. Removed the acm and program a custom hondata tune with the stock ecu nothing still lean. So he hooked up back the acm did a reflash to adjust timing, vtec, surging etc so I dont blow my motor. He took a look at the fuel trim and its having to add 10-15% which is not good he said. He said for the shop to check on the crushed fpr. They will do this in the next 24 hours. The tool they used on my car is the new tool, and I was the first car who used this new tool. All the other several cars with comptech supercharger had the old tool. They said the new tool just crushes it on the other end no big deal.
any advice? Hondata said to check the stock plug since the 05 and 06 are different. The A and E?
thanks,
Michael
Old Mar 1, 2007 | 01:14 AM
lookinco's Avatar
B A N N E D
You are not getting enough fuel. If adjusting the ECU doesn't help, then it must either be the fuel pump, FPR, or bad fuel injectors.
17s is super lean, don't blow up your motor.
Old Mar 1, 2007 | 01:19 AM
mmcv6's Avatar
313.4WHP& 284.6TQ
I was either thinking fpr, I bought a new one and have the old style tool which my shop used several times and it worked 100% so if needed I will use this. Or the a and e plug along with the acm wiring since 05 and 06 are different?
hmmmm
Old Mar 1, 2007 | 09:21 AM
bklynpanman's Avatar
321 whp SAE
i had this problem when i had mine installed first.. it was the fuel pressure regulator.. get a new one and re-crush it..
Old Mar 1, 2007 | 09:31 AM
Black_05_TL_6SP's Avatar
Ryan Christopher
thanks,
Michael
Sorry to hear you are having problems with the S/C install. From many of the previous threads I have read, it does sound like the FPR. As bklynpanman had the same problem, he went on for ever trying to figure it out!!! j/k
But please, try to structure your sentences a little bit better the next time you post. I had a hard time reading through the post.
Old Mar 1, 2007 | 11:58 AM
JOES05tl's Avatar
So mike, did you mod your exhaust yet? Hows it sound? I'm really interested in hearing it. Also, I thought you were bs'ing when you told me about putting on the supercharger cuz' everyone says their 'gonna' get it. Damn!
Old Mar 1, 2007 | 12:43 PM
mmcv6's Avatar
313.4WHP& 284.6TQ
Just going to wait for the shop to open and they will figure it out. Just wanted some ideas of what to check out.
** The custom comptech setup I got sounds stock. Just the way I like it..hehe
Old Mar 1, 2007 | 01:20 PM
JOES05tl's Avatar
Very nice!
Old Mar 1, 2007 | 03:19 PM
special-ed's Avatar
Iro Ridg .308
I don't have a charger, but the FPR was the first thing that came to mind since depending on who crushed it and what tool they used to measure it seems to be the part that would have the most variable/difference in tolerance.
Old Mar 1, 2007 | 03:54 PM
MichaelBenz's Avatar
CTS-V Import Slayer
Does anybody have pictures of said tools so you know if you got an old one or a new one in your kit? Mine looks like a hand sized round peice of alum that has been milled and you put the FPR into it - put the cap on and crush it in a vise or something. It appears that you CANT overcrush it this way. I will snap a pic later tonight of it. I wonder if you can get pics of both tools on here so people can compare.
Old Mar 1, 2007 | 05:10 PM
mmcv6's Avatar
313.4WHP& 284.6TQ
I have the new tool. My friend who has the 04-06 tl comptech supercharger has the old tool. If we need to crush the fpr again we shall use the old tool this time.
thanks
Old Mar 1, 2007 | 05:58 PM
CTS-V Import Slayer
thanks
Oh...now that would be too convenient.....take a pic of em side by side so people know which is which?
Old Mar 1, 2007 | 07:28 PM
Allout's Avatar
Blown is Best
Have you thrown a fuel pressure gauge on your system to see what actual fuel pressure you're running?
Old Mar 2, 2007 | 12:57 AM
mmcv6's Avatar
313.4WHP& 284.6TQ
"Have you thrown a fuel pressure gauge on your system to see what actual fuel pressure you're running?"
I was just about to ask about this. My buds shop was wondering what the stock fuel pressure is on a 04-06 acura tl auto if it matters?.. Also what is the fuel pressure after the comptech supercharger?
He believes its like 50-60 at idle?
If anyone knows please let me know. They had to move shops and we did not have time tonight to check it out since we put the racks up. We shall check it tomorrow.
I also bought the Zeitronix wideband which shall help.
thanks all for your help.
Old Mar 2, 2007 | 01:39 AM
lookinco's Avatar
B A N N E D
On mine, it is around 50~60psi stock. With the crushed FPR it's up to around 80psi.
Old Mar 2, 2007 | 02:53 AM
mmcv6's Avatar
313.4WHP& 284.6TQ
"On mine, it is around 50~60psi stock. With the crushed FPR it's up to around 80psi."
thanks for the information. But I thought once you crush the stock FPR it sopose to increase it by 10psi about only? am I wrong?
Old Mar 2, 2007 | 03:02 AM
lookinco's Avatar
B A N N E D
I am not too sure. I am just telling you what my fuel pressure gauge is showing me.
Old Mar 2, 2007 | 08:10 AM
CTS-V Import Slayer
Good info here.
Old Mar 2, 2007 | 12:57 PM
mmcv6's Avatar
313.4WHP& 284.6TQ
ok talk to hondata and the ecu a and e plug for 05-06 are ok.
Also hondata said, the fuel pressure at idle and in boost should be the same. He does not know the fuel pressure when I asked. But he said, the 04-06 fuel pressure is the exact same. So if anyone has a service book if you can check for me.
thanks
Old Mar 2, 2007 | 04:49 PM
CTS-V Import Slayer
thanks
An ACURA service book to give you OEM readings or a Comptech service book to tell you what they should be crushed?
Old Mar 3, 2007 | 02:04 AM
mmcv6's Avatar
313.4WHP& 284.6TQ
update
Its about 1150pm friday we got it fixed. It was the FPR. I bought a fuel pressure gauge and when the new tool the fuel was at 60psi. So we put the stock FPR and it was 62psi. Then we crused the FPR with the old tool and my fuel pressure went up to 72psi.
We did not install the wideband since its so late and we shall put it in next week.
I did 3 runs, one wide open and it was super fast. Unreal... hehe...
Two runs at the area which surging occurs. And the surging is gone.
Only problem is my check engine light came on along with the vsa etc. Code is
P2227 Baro sensor range performance problem.
As I understand it. This deals with the reflash by hondata and I will have hondata fix it this week.
thanks everyone for your input.
Old Mar 3, 2007 | 06:07 AM
lookinco's Avatar
B A N N E D
glad to see you got everything working!!!!
I was just reading your meet thread and found out you got your supercharged installed at C&C. I was tallking to the supercharged accord guys that C&C are going to make polyurethrane engine mount for the 6th and 7th gen Accord and 3G TL. Do you have any more info about that?
As for the meet, I will still be in Califnornia on the 4th so I might drop by!
Old Mar 3, 2007 | 10:10 AM
BustedJack's Avatar
The Boss
very nice! Dave (bklynpanman) nailed it there. I was going to say its the FPR but like many have said here, it was. Glad you got it to work and enjoy the ride. Spring is coming that means weather will get nicer each day and you'd be able to test out that beast. But I always prefer winter over summer for car speed. When it's 20 degrees out, S/C'd TLs are a beast vs 90 degrees weather
Old Mar 3, 2007 | 10:40 AM
dan.....k's Avatar
^ So true. The summer sucks.
Old Mar 3, 2007 | 12:14 PM
mmcv6's Avatar
313.4WHP& 284.6TQ
"glad to see you got everything working!!!!
As for the meet, I will still be in Califnornia on the 4th so I might drop by!"
If you are in California stop by the meet/bbq... c&c will talk more about the poly mounts for our cars at the meet. If you got any questions they will answer it.
Old Mar 5, 2007 | 12:01 AM
OMP Prelude's Avatar
13.19@105.48MPH
what fuel pressure gauge are you guys using ?
Old Mar 5, 2007 | 09:19 PM
Allout's Avatar
Blown is Best
I picked up a manual one that I need to install. I've got a Marshall Performance 1 1/2 inch liquid filled unit 1-100psi. It was a cheaper alternative to an in-cabin gauge and gives the ability to check base pressures. Manual is accurate. I've heard of problems with the autometer electric gauge.
http://www.marshallinstruments.com/catalog/performance.
Old Mar 9, 2007 | 01:13 AM
encrypted03's Avatar
Where do you guys tap into the fuel line? I've been trying to get this gauge installed for the past 4 months
Old Mar 9, 2007 | 09:28 AM
03TL_S's Avatar
2006 TL-S.C. 6mt
where do you tap the supercharger for the boost gauge install
Old Mar 15, 2007 | 08:57 PM
On the back of the intake manifold there is a line before the solenoid. Ryan helped me out with finding that one
Anyone?
Old Mar 15, 2007 | 11:06 PM
13.19@105.48MPH
i dont know where to tap into for the fuel pressure yet, im working on getting my guages first when i find out i will post it , if anyone didnt yet
Mike Pilipenko
Mar 26, 2024 09:21 PM
SidhuSaaB
May 30, 2020 12:40 AM
12vancover
Oct 16, 2015 12:04 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
MikeJM310
Sep 24, 2015 07:24 PM
