Clutch Replacement: Stage1 suggestions
All motor
This. I'm full bolt on and went with Stage 1 only because I got a great deal on it, and because I wanted a lightweight flywheel. Otherwise, the stock clutch can hold the power I have. Get the Exedy OE replacement.
runnin a little boost
You can go with the 6 puck p2r clutch disc, I'm running it and like it a lot. It is a little harsher engagement, just enough to remind you it's a performance set up. It also works with the stock flywheel and pressure plate, so you only have to replace the disc, unlike most of the aftermarket clutch sets that require you to change the FW and PP. It's more holding power than you will ever need, but at the same time this is an axle braking clutch if you slam gears.
veggiemonster (09-09-2011)
Former Sponsor
http://store.excelerateperformance.c.../i-173604.aspx
what is a good price on the p2r disc (from a good retailer)? i'm searching now and getting some conflicting pricing
This IS a axle breaking clutch if you slam gears. The TL uses a unsprung clutch disc and a dampened flywheel. This mean all the shock from a hard gear change is going straight to the drivetrain. This is the clutch Rodney was using to Put down the crazy numbers he was with the turbo. The disc should cost about $180-$250. Look on p2r's website Rodney's seems to be down.
You could also consider a Spec Stage 1 if you're looking for a slight improvement on a budget.
SidhuSaaB
05-30-2020 12:40 AM
