Changed my air filter to K&N...all by myself!
Old 03-08-2011, 11:28 AM
  #41
#ForcedInductionFamily
WRXtranceformed's Avatar
Originally Posted by I hate cars
I was about to say why settle for an E class when there's the CL. I had just gotten approved for the loan two months ago for a CL65 Brabus when the friend I was buying it off of totaled it. It's amazing how cheap you can find those cars after a few years. I was going to pay $32,000 for a 704hp twin turbo V12 CL65 with 60,000 miles and a warranty past 100,000 miles.
Ahh so sick! too bad that never panned out. what are maintenance and insurance costs on those things like?
WRXtranceformed is offline
Old 03-08-2011, 12:15 PM
  #42
HighRevving's Avatar
whose the noob that quoted the pictures.....
Ok so what's wrong with quoting the pictures?? I mean 'these' pictures? Maybe someone indulged in looking at them again - to confirm the brand on that air filter.
Ok back to topic,
Label Snob, do you mind putting up a DIY with picture for us?
(guys, if this works as I planned, you will owe me big time)
HighRevving is offline
Old 03-08-2011, 12:18 PM
  #43
ggesq's Avatar
Received 2,183 Likes on 1,211 Posts
Ok back to topic,
yeah, maybe she'll fall for your plan and do it in her bikini
get real. c'mon guys. let's keep the leg humping to a minimum?
Props to you OP- my wife wont come near the car (other than to sit in it) much less the engine bay.
ggesq is offline
Old 03-08-2011, 01:30 PM
  #44
So much for little humor.
I think we all attained the moral of thread. The OP changed an air filter. Doubt we can derive anymore wisdom out of it so might as well close this puppy.
Old 03-08-2011, 01:32 PM
  #45
Received 16,267 Likes on 11,974 Posts
^dont have to close.....
justnspace is offline
Old 03-08-2011, 01:50 PM
  #46
'06 WDP TL 6MT
stvtec's Avatar
Good job getting your hands dirty. That is definitely an attractive trait. To us, at least.
stvtec is offline
Old 03-08-2011, 01:54 PM
  #47
I hate cars's Avatar
Received 1,812 Likes on 1,283 Posts
Originally Posted by Majofo
I'm guessing more than once they've ridden in the passenger seat with you and had delusions of grandeur when they got in the driver's seat.
You could probably blame in partially on me. I showed him how to put it in dyno mode. The only electronic nanny remaining is ABS. No traction control or stability control. Usually the ECU delays full throttle for 2 seconds with a 2 second ramp up from the time the pedal hits the floor. Those two little turbos on the 6.5L V12 spool pretty much instantly so it gets real crazy real quick. The day before he bet me I couldn't go around this extremely long right hand on-ramp sideways the whole way. Not sure if he attempted the same or not. I still can't believe how that car held up though. It's a tank for sure.
WRX- I would not own one of those without a good warranty. This friend of mine has owned 5 of them in as many years and each one has had major front suspension problems, auto closing doors and trunk not working, and active suspension failing. That gets embarassing because the car floats and leans worse than an old Cadillac when it goes out. The front suspension alone would have been close to $14,000.
As far as basic maintenence, not too bad. I do the brakes on them for about $250 if rotors are not needed. You can get 24mpg on the freeway if you drive nice. I can't remember how much oil it holds but it's a lot. My particular friend puts the cheapest stuff he can find at the time. My ex also drives one and it has pretty much the exact same problems.
They are a pleasure to drive. There's power from idle to redline on the V12. You would not know it's turbocharged just from driving it. Full boost comes in at 1,200rpm. No road noise, no wind noise, just silence going down the freeway. The ride is absolutely amazing, you can see other cars bouncing over bad freeway sections and you can barely tell you're on bad pavement. Pretty much no body roll when the ABS is functioning correctly. Steering is precise and actually gives a little feedback. There's no indication of the car's 5,200lbs unless you put it in dyno mode. Once it starts sliding, it goes and goes and goes. You want to have a lot of pavement if you plan on going sideways.
The stock audio is good enough. Mids and highs are better whan some mid price aftermarket stuff and it has a factory 12" sub that's ok. The only thing we've ever upgraded was the sub and amp.
There are little things that make it so nice. You can raise the front end up for ground clearance at the touch of a button. The doors are double hinged so they require much less room to fully open which helps in tight spaces. The side view mirrors fold in as you're parking. And about a million other small features. It's just one of the best driving cars I've ever had the pleasure to drive. It's so refined but packs 704hp and I *think* close to 1,000lbs of torque. Now it's not quick like you would imagine a 700hp car because it's so heavy. The GN spanks it badly but if I had to guess I would say it would go deep in the 12s and probably 120-ish traps on street tires. It's so hard to guess because it's quiet and doesn't transfer weight like most cars.
I hate cars is offline
Old 03-08-2011, 02:24 PM
  #48
Dang 120ish traps would translate to 11s if you could get some sticky tires and some seat time in. Sounds like an awesome tourer...other than the possibility of massive expensive failures haha
Old 03-08-2011, 03:32 PM
  #49
Carly Curran
Label Snob's Avatar
I'm sure when summer comes and my bf finishes rebuilding his celica all-trac I will have some more pictures
Label Snob is offline
Old 03-08-2011, 03:34 PM
  #50
Best friend right?
Old 03-08-2011, 05:47 PM
  #51
under renovations....
CubanLynx84's Avatar
CubanLynx84 is offline
Old 03-08-2011, 06:30 PM
  #52
RAR
leedogg's Avatar
Received 1,286 Likes on 714 Posts
^ a good fucking trap.
why didnt I think of that...
leedogg is offline
Old 03-08-2011, 11:36 PM
  #53
Former Whiner
Souljah's Avatar
Pizzaman, you have PM
Me too!?
Souljah is offline
Old 03-09-2011, 12:52 AM
  #54
P1zzaman's Avatar
Originally Posted by Souljah
Me too!?
This thread is quickly turning into Sheen's Korner.
P1zzaman is offline
Old 03-09-2011, 06:35 AM
  #55
Good job, label on changing the air filter!
Old 03-09-2011, 09:15 AM
  #56
Majofo's Avatar
Received 11,843 Likes on 8,574 Posts
pm bro?
Majofo is offline
Old 03-09-2011, 09:31 PM
  #57
TLMunchkin37's Avatar
Hey girl, Good Job!
Kind of funny you posted this just a couple days ago, I'm another "hands on" woman with my TL and just ordered a new K&N filter this afternoon. I plan on putting it in myself when it arrives this weekend; thanks for the tutorial!
Found this upon searching and it helps!
TLMunchkin37 is offline
Old 03-10-2011, 09:24 AM
  #58
@TLMunchkin37: You go girl!
While Lable is putting together the DIY with her uumm
Best friend right?
Maybe we can get together, sip few cappuccinos and chat about the cons of K&N - Better hearing from me than that gearhead 'I Hate Cars'
Oh wait, I think I have K&H in my TL as well.. Ok scratch that..
Disclaimer: Humor
Old 03-10-2011, 09:37 AM
  #59
flyromeo3's Avatar
^..... acurazine = eharmony ?
flyromeo3 is offline
Old 03-10-2011, 09:43 AM
  #60
Majofo's Avatar
Disclaimer: Humor
You want to get together with Justin and slurp some cockaccinos. Don't do it Justin.. it's probably a trap.
Majofo is offline
Old 03-10-2011, 09:53 AM
  #61
I didnt know how to respond to his advancements towards me.
But i do believe its a trap, and I'm not falling for it.
Old 03-10-2011, 10:09 AM
  #62
Lol. Its no wonder we have so few female members.
Justin, let us know how it goes. :gheylaugh:
Old 03-10-2011, 10:20 AM
  #63
I really really dont want a cockaccino.
Old 03-10-2011, 10:22 AM
  #64
Majofo's Avatar
I really really want a cockaccino.
Majofo is offline
Old 03-10-2011, 10:36 AM
  #65
d0rks lol,
The whole response was for TLMunchkin37 and was supposed to be interpreted as:
While Lable is putting together the DIY with her [best friend], then invitation..
Get you heads out of uum the engine bay and breath some air
Now if you actually did get it the first time but still made me type this up then +1! lol
Edit: ^ Majofo, you are just EVIL lol
Old 03-10-2011, 10:41 AM
  #66
^you really dont have to explain...
we all know your true intentions, I'm quite flattered.
Where do you live again?
Old 03-10-2011, 10:43 AM
  #67
Majofo's Avatar
Acurazine will always be a sausage fest. I'm going to sign up on the purse forum.
Majofo is offline
Old 03-10-2011, 02:30 PM
  #68
6th Gear
needfd's Avatar
good job, and a good write up for others.
needfd is offline
Old 03-10-2011, 04:59 PM
  #69
3G TL/2G MDX Owner
TLtrigirl's Avatar
ya think? i'm gonna take a guess here and say that the leg humpers out there...do you guys even have GFs? i mean really, do you really think you're gonna get a respectable girl if you keep throwing the leg humping out there?? its not very flattering nor classy. i know its all fun and games (i hope), but there are certainly better ways to express your...attraction to a girl that is into cars.
TLtrigirl is offline
Old 03-10-2011, 05:14 PM
  #70
Majofo's Avatar
Most of active members here are either married, or are in long term committed relationships. For the most part, the active members who have been here for a while are very respectable guys. The leg humping is just our standard greeting to new ladies on Acurazine. If you take us serious, this isn't the place for you. If you insult us.. you're in the right place.
On a serious note, Acurazine is a great community and anything that would generally cross the line in the workplace is not tolerated here.
Majofo is offline
Old 03-10-2011, 05:40 PM
  #71
I'm only playing and as Majofo stated, Dont take us too serious.
I'm currently confused, tho. High Revving seems like a nice boy.
Old 03-10-2011, 05:46 PM
  #72
AZ Community Team
Bearcat94's Avatar
Received 7,771 Likes on 4,342 Posts
On a serious note .... anything that would generally cross the line in the workplace is not tolerated here.
And yet, we allow you to stay.
You sir (an I use that term with the utmost sarcasm), are the exception to prove the rule.
Bearcat94 is offline
Old 03-10-2011, 08:34 PM
  #73
Majofo's Avatar
Well I was the first member you banned when you became a mod.
Majofo is offline
Old 03-10-2011, 09:15 PM
  #74
AZ Community Team
Bearcat94's Avatar
I was a ; I didn't know they were using you as a bad example. But now we have justnspace; you trained him well.
(I don't even remember that actually)
Old 03-10-2011, 09:20 PM
  #75
Did someone say ban?
Old 03-10-2011, 09:22 PM
  #76
^lol how many times have you been banned?
twice for me.
Old 03-10-2011, 09:33 PM
  #77
twice for me.
Three times I think.
Old 03-10-2011, 09:38 PM
  #78
erick3's Avatar
i'm confused...maybe because i skimmed through? this isn't your TL, but...someone you sold your TL to? for a second, i thought you were in sales...but it looks like...somewhere you switched it back to being your TL? lol sorry!
GOOD FOR YOU by the way
erick3 is offline
Old 03-10-2011, 09:57 PM
  #79
Majofo's Avatar
Ron A pardoned me.
Majofo is offline
  #80
Majofo's Avatar
twice for me.
You took one of those for the team though.
Majofo is offline
Quick Reply: Changed my air filter to K&N...all by myself!
