Cams for 04 TL
Old Jun 12, 2007 | 03:06 AM
Beerhatguy's Avatar
8th Gear
Cams for 04 TL
Dose any1 out there have a aftermarket cam for the TL?
Old Jun 12, 2007 | 03:51 AM
ussi's Avatar
I (don't) whine.
07 TL-S cams fit, I think RL as well.
Old Jun 12, 2007 | 05:50 PM
jdmspec333's Avatar
.43g at 900+fps
i got 07 tl-s. if you want a true aftermarket, you'll have to settle for webcam's regrinds.
Old Jun 14, 2007 | 09:00 AM
Beerhatguy's Avatar
8th Gear
Thanks I just tired to type in webcam's regrinds in google and i couldant find anything for the TL what the main website link?
Old Jun 14, 2007 | 09:10 AM
Beerhatguy's Avatar
8th Gear
Dose the Type S cams really make a big diffrence?
Old Jun 14, 2007 | 03:10 PM
722ish's Avatar
71Q
what specs will these webcams be? That sounds like a really good idea!
I wonder if delta cams will work em over as well?
Old Jun 14, 2007 | 03:34 PM
jdmspec333's Avatar
.43g at 900+fps
you gotta call webcam. it's not on their site. if i remember correctly it's gonna be about 600-700 bucks and it takes 3-4 weeks. if anything you could buy factory cams and send those over to them so your car won't be down for all that time. or you could spend under 400 bucks and get tl-s. i was in a hurry so i got tl-s. i think it was a good investment.
Old Jun 21, 2007 | 03:57 AM
722ish's Avatar
71Q
Whats the lift, duration and such on the S cams. And what is advertised, and whats useable lift on them , if you dont mind me asking...
Old Jun 21, 2007 | 08:11 PM
jdmspec333's Avatar
.43g at 900+fps
it's on another thread. all i could provide was the lift spec. my machine shop got me the specs...
Old Jun 21, 2007 | 08:17 PM
jdmspec333's Avatar
.43g at 900+fps
it's in the "engine port and polish" thread by ussi...
Old Jun 22, 2007 | 02:22 PM
seoulja's Avatar
hey guys i noticed someone said the 07 tl-s cams fit?! isnt the new 07 tl-s a 3.5 ltr ? cams are the same? and also....i was thinking and wondering if the 02 cl-s cams would fit the 04-06 TL ...and why did u choose the 07 tl-s cam? im seriously trying to upgrade my car so if anyone w/such knowledge could help me i would really appreciate it!
Old Jun 27, 2007 | 12:52 PM
722ish's Avatar
71Q
The TL-s motor is the same series as the 3.2 tl. There is no reason all the internals should be much different, because the motor is of almost identical design. The displacement has little bearing on the different cylinder heads.
thanks JDMSPEC
Old Jun 28, 2007 | 11:12 PM
seoulja's Avatar
i see.. thanks for the reply...but did u notice alot of difference in hp? and did u have to do a valve adjustment after installing the 07 cams? im just wondering if webcams or TL-s ...which is the most for the buck.
Old Jun 28, 2007 | 11:14 PM
ussi's Avatar
I (don't) whine.
you don't have to, you can replace the valve springs which have 2lbs more tension on them or replace the entire head as the type-S has bigger intake valves.
ExcelerateRep
Oct 14, 2015 08:20 AM
kmarqueling
Oct 3, 2015 01:14 AM
Papa Roe
Sep 26, 2015 11:45 AM
95oRANGEcRUSH
Sep 25, 2015 12:50 PM
V12 Inspire
Sep 10, 2015 04:46 PM
