Brembo brakes
If you have a 6sp manual TL, it comes equipped with the brembo brakes. If not, to upgrade to the FACTORY brembo brakes are around 2-3K. There are other options such as Big Brake kits, I advise you check out the modifications thread that is stickied to the top of the page for more info.
yes- a little more info would help- especially which transmission,, as the 6 speed manual gets the brembo 4 piston calipers and 12 inch rotors
while the auto gets single piston caliper and 11 inch
(it may be 13 and 12)
There are a few good options on rotors and pads depending on how you drive
My tl is 5at. I was looking for the brembo sport high performance braking system, which features racing inspired cross drilled or slotted rotors(never drilled and slotted) i was also looking for the brembo calipers to replace the factor ones.
pm excelerate there are great deals on bbk's right now...
Excelerate will tell you to use the 6 piston WilWood calipers if you are going to spend the money
It will require some steering parts being changed to fit larger rotors and caliper space
for basic better braking talk to excelerate about Rotora parts and also to MrHeelToe for RacingBrake parts on rotors and pads
see Off Topic Link-top of azine page- then scroll to Sponsored Sales for their ads/threads and link to websites
SS brake lines are a nice upgrade too
AFAIK, there is no bolt-up Brembo system for the AT (non-Type S).
As mentioned your options are After market BBK (Rotora, etc), After Market OE replacments/upgrades (Rotora, Racing Brake, etc Rotors/Pads) or OE knuckle, etc replacemtns to mount the MT/TL-S Brembo calipers, then find some Brembo Drilled or Slotted rotors.
GWEEDOspeedo
Jan 15, 2016 10:39 PM
rockyboy
Oct 2, 2015 10:45 PM
