big break qustons
Old May 2, 2007 | 05:24 PM
Acura04Cee's Avatar
Exclamation big break qustons
are there big break options for the 2004At larger slotted and drilled roters and calipers is it and option or no and if it is what are my otpions i searched the fourms but couold find anything
Old May 2, 2007 | 07:18 PM
varanelli's Avatar
Rotora makes a BBK. Both front and rear available. Excelerate sells them in the Black Market section.
You can also search using "brake" instead of "break."
Old May 2, 2007 | 07:29 PM
01tl4tl's Avatar
Agree
Excellerate sells Big Brake kit with 1 inch larger diameter slotted rotors and 4 piston caliper$$$$
I wish I had them!
MrHeelToe has the RacingBrake brand 2 piece slotted rotors- lighter weight with vastly improved cooling- while staying with same calipers you already have
What your actual needs are should determine your purchase
see www.racingbrake.com and www.hawkperformance.com to learn all about brake rotors and brake pads
Old May 4, 2007 | 10:11 AM
Excelerate's Avatar
Former Sponsor
ROTORA offers 3 different kits:
1 pc 330MM Rotor w/ 4 Piston Caliper
2 pc 330MM Rotor w/ 4 Piston Caliper
2 Pc 355MM Rotor w/ 4 Piston Caliper
You can get slotted or slotted and drilled. The kits also come with SS brake lines for the front and caliper brackets and high performance ceramic pads.
Jul 16, 2017 07:33 AM
Jinkazetsukai
Nov 21, 2015 05:28 PM
lanechanger
Oct 13, 2015 10:56 AM
Froid
Sep 27, 2015 06:16 PM
