big break qustons
are there big break options for the 2004At larger slotted and drilled roters and calipers is it and option or no and if it is what are my otpions i searched the fourms but couold find anything
Agree
Excellerate sells Big Brake kit with 1 inch larger diameter slotted rotors and 4 piston caliper$$$$
I wish I had them!
MrHeelToe has the RacingBrake brand 2 piece slotted rotors- lighter weight with vastly improved cooling- while staying with same calipers you already have
What your actual needs are should determine your purchase
see www.racingbrake.com and www.hawkperformance.com to learn all about brake rotors and brake pads
I wish I had them!
Former Sponsor
1 pc 330MM Rotor w/ 4 Piston Caliper
2 pc 330MM Rotor w/ 4 Piston Caliper
2 Pc 355MM Rotor w/ 4 Piston Caliper
You can get slotted or slotted and drilled. The kits also come with SS brake lines for the front and caliper brackets and high performance ceramic pads.
Jul 16, 2017 07:33 AM
lanechanger
Oct 13, 2015 10:56 AM
