Battery replacement with the supercharger?
I need some clarification on the battery everyone is using with the supercharger. I read in a post that I need the 51R but according to Optima's terminal layout, the positive terminal for the 51R is on the right side. When I looked at my battery, the positive terminal is on the left side. So now i'm thinking I need the 51 instead? Can any of you supercharged TLs help me out?
BTW - Do you think the Optima is worth the money or would you recommend another brand?
runnin a little boost
8 second & 150 mph member
stick with a 51r the interstate battery is a good choice. dont get the optima there 51 series suck, had to replace mine after a year with the s/c on. you do not need to remove the s/c to replace the battery either. just had a customer with a one year old braille that went bad already so dont think that they are any better then optima.
347hp/300tq @ 4psi
just save yourself the trouble and buy yourself a good battery relocation kit. i kick myself in the ass for not doing that in the first place, cause when the battery goes, its a major PITA to change it out. whats great too is you can run a normal size battery and add some much needed weight in the rear of your heavy FWD car for better weight distribution.
i bought the taylor kit for only 100 bucks and didnt need the box since i went with the optima yellow which is sealed. only bad thing about the optima battery is it weighs about 50lbs 0_O but it counters the extra 50+ lbs the charger kit adds to the front.
mada51589
05-03-2022 08:54 PM
cycdaniel
12-17-2019 10:58 AM
BlkTxAcuraTypeS
10-18-2015 08:05 PM
05, 51r, acura, battery, change, inspire, interstate, mt51r, optima, relocation, replacement, siteacuratsxcom, supercharged, supercharger, tl, tsx
