ATLP Quad Exhaust for 2004-2006 Base TL
#122
Originally Posted by Black_dc2
Is the exhaust still avail. for purchase? The original post link for a deposit doesn't work.
The current batch is sold out, but visit www.acuratlparts.com, and go to ATLP Exhaust to put a deposit on the next batch. We are working hard right now to get the 2nd batch out in the next 2 weeks!
#125
horny =
Got mine today and I am very impressed with the work. Did not expect the etching!
Couple questions:
1. I have not recieved my tls rear should I wait to install the exhaust and do it all at once (would it make it easier?)
2. Can I do this? Got two 3 ton jacks but is it bolt on bolt off? Or should I take it some where where they have a lift.
I can't wait to hear what it looks and sounds like!
Couple questions:
#126
horny =
Couple questions:
Couple questions:
#128
94 DC4 RS LSV/Turbo
if you make the cuts you can roll around with a cutup bumper which isn't the worst lol
if you have some lube (I used the lube the tire shops use to mount wheels), you need to lube up the rubber hangers or else you will be pulling and tugging forever, also put lube on the hangers of the new exhaust before you put them in the rubber hangers, they all slip right in, without lube you got to get your back into it
#129
Couple questions:
Couple questions:
1. I think if you do it all in one shot, it would be less of a hassle, having to go under your car again, get your tools out, etc.
2. It's very DIY-able. 3 bolts by the cat, 2 bolts behind the muffler canister, and a few hangers. I used WD-40 to soak the bolts/threads a few hours before, and then soak the hangers right before you try to pull those out. (The hangers will absorb the WD-40 if left for long and it won't be as slippery anymore)
Good luck! PM me if you need help with anything!
#130
Iro Ridg .308
Originally Posted by chris80i
ANYONE IN THE BAY AREA INTERESTED IN PURCHASING A ATLP EXHAUST SYSTEM? USED FOR A LITTLE OVER 1 MONTH? PM
#131
.:KCCO:.
WD40 works just fine.
i dont kno how to do it without that stuff. i tried and theres no way
#136
Former Sponsor
Originally Posted by Fulani has a TL
OK so my ATLP was installed on Friday of last week, Its PERFECT except that the left tips are about half an inch higher than the right side... What can I do about that?
at first my left was 1" higher and the right sagged alot, so i did this method mentioned above...it is now sitting much better but the left is still just a bit higher, will try it again today.
#137
94 DC4 RS LSV/Turbo
get 2 friends to hold each muffler, make sure they position them the way you want then retighten, obviously the car is on a lift at this point, lol
my problem wth my greddy was very similar
#141
Originally Posted by Kennedy
Mike... where's that second batch shipment baby? TL-S lip is on the way!
Anyone want a good deal on my WDP 04-06 rear lip?
...but no fear..I don't sleep. lol
#147
So I am about to buy a aspec kit, so if I get a type-s rear lip. This exhaust would fit and is readily avail.?
#151
'10 Hyundai Genesis Coupe
Make sure though if you're putting the Type S aspec rear lip on an 04~06 base TL you will need to cut the rear bumper a little but in order for it to look right. There is a thread on the forums.
#156
A-spec steering wheel ftw
LOL nice Rallye License plate frame annnnnd very subtle plate name ;-)
but yea, that looks great! I wonder if there is anyway to tuck the pipes up a lil higher?
btw....you're so freaking anal, your A-spec kit job was done great, actually from directly from the back it looks really really well done.
i'm gonna be back in NY after May i gotta def check out your new TL in person!
#157
I have car ADD
well, with the 07+ TL-s rear aspec lip, there is actually black plastic molding inside the exhaust cut out... you have to remove the OEM grey molding when install this. so the exhaust sits pretty flush, and i think the ATLP looks GREAT with the 07+ Rear TLS lip.. better then on the stock bumper..
