Atlp J Pipe Gaskets
Old Jun 30, 2008 | 05:47 PM
BADSHARK's Avatar
07 Type S NBP
Atlp J Pipe Gaskets
Hey, guys need some help. Just recieved my J pipe and it has the 2 small flange gaskets with it but nothing for the rear flange. Question is does this just go metal to metal? Vehicle is in the air as I write this.
Old Jun 30, 2008 | 09:38 PM
AndrewA's Avatar
All the pics I've see show the 3rd cat has o-ring gaskets. As long as you can verify that the o-ring is in good shape (you might want to clean it with a non-petroleum based cleaner, just don't rip it), and isn't flattened (it should be higher than the cat flange surface) you should be fine.
Old Jun 30, 2008 | 10:00 PM
Kennedy's Avatar
OMGWTF4THGENTL
Mine came with three gaskets... You'll be fine to run without until Mike sends you one.
Old Jul 1, 2008 | 12:10 PM
BADSHARK's Avatar
07 Type S NBP
Thanks for the input guys, metal to metal worked just fine. Man does it pull hard now on the top end.
Old Jul 1, 2008 | 01:05 PM
AndrewA's Avatar
Can't wait to put mine on. Fed Ex delivered today. But... the 3rd cat test pipe, which shipped the same day won't be in until tomorrow. Go figure...
Old Jul 1, 2008 | 05:19 PM
aznbo187's Avatar
The J-pipe comes with 2 gaskets, or 3 if you have the race pipe. It will work fine without it as the factory cat has a built in O-ring. You can also just use some gasket sealant, or if needed, I can always send you a gasket.
Old Jul 1, 2008 | 06:23 PM
AndrewA's Avatar
Hey Mike,
I just got my J-pipe. The race pipe should arrive tomorrow. Have you ever given thought to providing the self-locking nuts that Honda recommends replacing when installing these parts? These parts go through a lot of mechanical and thermal cycling and the hardware is likely to loosen. I'm going to run by the dealer and pick up 12 new 10mm x 1.25 self locking nuts tomorrow.
The J-Pipe is a work of art BTW...
Old Jul 1, 2008 | 08:04 PM
Kennedy's Avatar
OMGWTF4THGENTL
^ Good idea, but overkill...
I've had my jpipe on/off 4 seperate times over 20K miles, and never once were the nuts loose.
Old Jul 2, 2008 | 12:17 AM
aznbo187's Avatar
It's a great idea, but I don't think necessary in this application. I've had my J-Pipe and cat, as well as exhaust, on for 30K miles, through many heat cycles and track cycles but never had any problems with bolts coming loose either. It's not a bad idea though if you need that piece of mind.
Old Jul 2, 2008 | 12:32 AM
CS-SuperchargedTL's Avatar
SC TL to RS4 to 911
Just wanted to say thanks mike! They got it at the shop yesterday, can't wait to put it on!
Old Jul 2, 2008 | 09:08 AM
AndrewA's Avatar
hardware for J-pipe or race pipe install
got a bag of 9 self locking 10x1.25mm nuts from the dealer for 45 cents each. well worth my peace of mind.
Old Jul 3, 2008 | 09:56 AM
blkaspec's Avatar
Full of water...
i have had my race pipe for a few weeks now and i just received my j-pipe yesterday...i cant wait to get these things installed
Old Jul 4, 2008 | 12:38 AM
stillhere153's Avatar
94 DC4 RS LSV/Turbo
thanks for posting the part # on those locking nuts... now imma put a few of those... cuz I am rolling with some random ones
Old Jul 14, 2008 | 07:58 AM
nkgrusin's Avatar
Just received my J pipe last week and installed it yesterday. Very well constructed and was a better fit than the factory pipe. That being said I was surprised, especially after having read this thread about not needing the third gasket for the cat, to find that the o-ring is actually on the end of the factory pipe and not the cat (see attached picture of the factory J pipe and o-ring). I couldn't just put metal on metal or use high temp silicone. I learned my lesson on those two options a long time ago. So I ran out to AutoZone and bought a sheet of gasket material and made my own. No big deal, but I would recommend sending the rear gasket along with this great product.
Old Jul 14, 2008 | 07:59 AM
nkgrusin's Avatar
Picture did not come through. Here is the link:
http://docs.google.com/Doc?id=dhkz866h_0mxv5gj3c
Jul 16, 2017 07:33 AM
InFaMouSLink
Oct 27, 2015 06:52 PM
ExcelerateRep
Oct 14, 2015 08:20 AM
Rcelestino93
Sep 23, 2015 10:01 PM
