apexi vafc2 harness
apexi vafc2 harness
whats up guys new to the sight but have been on here plenty of time i have a 2008 tls 6spd n have been itching to tune my ecu, well i have been reading up n it sux that they dont have a reflash for us beside the stand alone but just came to findout that we are able to put the vafc2 vtec controller in our cars that have the harness for it at Boomslang.com all u gotta do is buy the harness plug it to ur ecu n go get it tuned. the harness is about $150 shipped.
umm I thnk your on the wrong section then. this is Gen 3 TL 04-08.
You sir have a Gen2 TL. You can probably pull it off since I see the CL-S doing it also. You should be fine. But if you have a gen3 TL your only choice as of now is the AEM FIC
i have a 3rd gen but i had the vafc in my 2nd gen just wanted to know if it was possible to putting it in the 3rd gen seince i already had it,plus with the harness would be pretty easy install since i do everything myself. why are some members saying its not possible?
And the F/IC isn't all it's cracked up to be either. We're still lacking any sort of closed-loop solution. (read: The ECU will still see that the car is too lean/rich and compensate for any adjustments made) I'm working on something to help us F/I guys with this exact issue, but anyone N/A is going to be out of luck. One other note about the F/IC - you can't advance timing so it's not all the helpful for N/A tuning.
If you're N/A, just hold tight. Stuff is on the way, but it could take up to a year before it's available. If you're F/I, you pretty much have no choice but to run the F/IC (or similar) for the being and hope that your tune is good enough to get you by until these O2 skew modules become available.
That being said, I don't know just how much there is to squeeze out of a N/A J32 with a piggy-back unit. There are a few known issues that are playing against you. The biggest one is that these engines already knock to some degree in stock form. I also know that there is a rumor going around that Hondata has attempted to tune J32's before but ended up blowing motors. I'm not sure what the reasoning was. Again, this is a rumor and I cannot confirm its validity, but it's something worth thinking about.
xsilverhawkx
09-28-2015 06:51 PM
