Any way to reinforce an auto tranny?!?
Does any one know how to reinforce the Tranny besides with a aluminium cooler. Anything that will give the auto Tranny some balls.
Superstressed
@sloppyjoe, search Auto transmission threads and it will give you some ideas on how often to change you fluid and pressure switches. Check out the last post in this thread.
https://acurazine.com/forums/showthr...ssure+switches
sloppyjoe92 (12-24-2011)
Dude Come on 3rd n 4th pressure switches! That is not doing anything to beef up the transmission. This feels like a lost cause. Heavy duty components?? So I'm guessing no one knows anything about reinforcing auto Trannys.
takin care of Business in
Received 4,732 Likes
This is what i would do:
1> B&M external transmission cooler (optional but i would do it)
2> 3rd and 4th Pressure sensors (do it asap, replace them every 60K miles, i do)
3> Redline ATF (a 4x3 will last you 60K miles)
4> Drive in SS mode (i do all the time) this way you can avoid 4-2 shift....
This way you will have "reinforced" your tranny....
Bro chill out and put yourself in check. This isn't honda-tech or some rice forum. Treat people here with respect and you will get your answers. Now, I would highly recommend an transmission cooler, highly. I have one and let me tell you, within a minute that thing gets too hot to touch, more cooling, means more life on the fluid so it means it won't break down as fast keeping it's main function. Change out your fluid every 15k and you should be fine. As for re-enforcing there isn't any that I know of as in "racing" clutch packs or things like that.
The pressure switches are maintenance but if you want your tranny to last then I suggest you do it as far as from what I've read.
Okay guys, lets tone it down a notch...
You will probably have to send the transmission out to a rebuilding company to have them upgrade the internal components like the clutches, valves, passageways, etc.
Dr. Evil was one such company but a lot of folks have had bad experiences with their parts failing. I'm sure there are other companies that can do the work to improve the trans.
As far as trying to improve it yourself, look into installing a better filter and cooler for the transmission to help keep it cool under high stress situations. As well search for a post made by I hate cars. It details how you can modify the pressure switches to raise the pressure at which it shifts for a snappier one.
https://acurazine.com/forums/3g-tl-2004-2008-93/very-interesting-conversation-my-transmission-builder-tl-721508/
btw phee you mean "Very Interesting Conversation with my transmission builder" ?
engine builder
engine builder
Mr. Detail
Try Level 10, they do valve body mods and full rebuilds using heavy duty clutch packs and higher stall torque converters.
http://www.levelten.com/SearchResults.asp?Cat=28
lanechanger
10-13-2015 10:56 AM
