AIT Modification Research
Hey guys,
I've been searching around and have come across a lot of good info from I_HATE_CARS on curing his engine surging by relocating his AIT sensor towards his air intake in order to get more accurate ambient air temperature readings. A mechanic friend of mine has 16 kilo ohm resistors that, when installed in place of the variable resistor, should cause the AIT sensor to read around -22F and thus pushing more fuel (maybe 1.08).
My main question is regarding long term buildup. I realize that these engines are designed to run lean in order to be economical, but other than somewhat of a MPG drop in the summer, what other side effects could I be looking at with this kind of modification? Would the gains here even be noticeable?
Thank you for your time and consideration!
ntmera (01-21-2014)
ntmera (01-22-2014)
Hey guys,
Relocating it down the tube or insulating the intake it to keep it from heat soaking and keeping the intake air charge cooler sounds like a better idea while allowing the AIT to read an accurate value for the air temp.
Don't know how much it'd be worth though really, mine is in a 4" plastic UBI intake with a nylon bung located just down the tube in front of the throttle body. My readings show about 2 degrees above the air temp measured on the MID sometimes while driving on the highway and ranges from 6 to 12 or more degrees above the temp on the MID while idling or driving on the street.
I have a 9" filter on the end of the 4" intake though, and the nose of it extends right down to where the grille mesh is on the driver's side of the front bumper.
My ECM is also advancing the timing up to around 40 degrees sometimes if I watch it on torque.
No issues with relocating the IAT sensor following this
https://acurazine.com/forums/showthr...age=3&t=803036
ntmera (01-22-2014)
Altering the AIT sensor to read an incorrect value and make the ECM think it has a cooler intake air temp sounds like a bad idea to me.
Wondering if anyone has tried this mod though. Anyone??
Maybe I'll be the guinea pig...
So I did this quick mod and can report an increase in throttle sensitivity. I'll mention that it did feel firmer when engaging the next gear (downshift or upshift), but this was so subtle it may be placebo.
Temps over the past week have been between -5F to 10F. I'm interested to see more results in this weather, but especially for the hotter temps.
08_UA7_Gr33k
02-11-2016 02:17 PM
