Air Intake Resonator Delete
Old Feb 26, 2014 | 10:46 PM
shenthan851's Avatar
Quick questions, if I do the air intake resonator delete will that allow water to go in? I read somewhere that the resonator also blocks out water.
Old Feb 26, 2014 | 10:52 PM
AsapChinky_'s Avatar
i heard that too lol, just buy a short ram intake and spend good money bro
i deleted the muffler resonator and it made me sound like a 1.8L civic lmao i had to waste money to put it back
Old Feb 27, 2014 | 12:01 AM
paperboy42190's Avatar
you were supposed to do the mid muffler not resonator lol
no resonator on stock exhaust = raspy sound
Old Feb 27, 2014 | 10:31 AM
Scottwax's Avatar
Mr. Detail
Removed the intake resonator on my Accord but my intake system is set up for quiet air intake and isn't as good at the TL cool air system. Definitely more free flowing now, tube that goes into the air box is barely into the fender so I'd have to drive through 2 feet of water for any risk of hydro-lock. There is an increase in sound but nowhere near what you get from an cone filter.
Old Feb 27, 2014 | 10:54 AM
the resonator doesnt block out water.
A resonator is a device or system that exhibits http://en.wikipedia.org/wiki/Resonance or resonant behavior, that is, it naturally http://en.wikipedia.org/wiki/Oscillation at some http://en.wikipedia.org/wiki/Frequency, called its http://en.wikipedia.org/wiki/Resonance_frequency, with greater http://en.wikipedia.org/wiki/Amplitude than at others. The oscillations in a resonator can be either http://en.wikipedia.org/wiki/Electromagnetic_radiation or mechanical (including http://en.wikipedia.org/wiki/Acoustics). Resonators are used to either generate waves of specific frequencies or to select specific frequencies from a signal.
2nd, if you're driving your car into huge bodies of water, maybe you shouldnt drive.
Old Feb 27, 2014 | 01:33 PM
nttstt444's Avatar
LOL
-Op you will be fine to remove the intake resonator box. The car will just be louder under acceleration. Theres a DIY here. You should be able to find it with a search.
Old Feb 28, 2014 | 05:09 PM
Hmm, alright thanks guy, imma go ahead and remove it. Hope it sounds better lmfao
Old Feb 28, 2014 | 05:15 PM
usdmJON's Avatar
A resonator is a device or system that exhibits resonance or resonant behavior, that is, it naturally oscillates at some frequencies, called its resonant frequencies, with greater amplitude than at others. The oscillations in a resonator can be either electromagnetic or mechanical (including acoustic). Resonators are used to either generate waves of specific frequencies or to select specific frequencies from a signal.
It blocks water too... not the point but it does.
Old Feb 28, 2014 | 05:24 PM
Follow the blue arrows go upwards in the tube and jump as there is a space, or no tubing. then the air goes back down the tube through the resonator.
this jump in piping would prevent water* from sucking up into the throttle body
*common sense dictates you shouldnt drive into a POOL.
Old Feb 28, 2014 | 05:44 PM
when you remove the resonator, take the pieces from up top near the battery area, and relocate them to the bottom.
you'll have to cut a piece off the resonator to achieve this. it uses the stock rubber couplers and the stock velocity stack.
the velocity stack, the piece near the battery, is specially designed to force more air in
it's not hard.
Old Mar 2, 2014 | 01:09 AM
where is that located?
Old Mar 2, 2014 | 01:19 AM
Eaglesfan9106's Avatar
I hate when people want to be spoon fed info. If only.they're were some type of website where all you had to do Is type something and information just popped up...If only...
Old Mar 3, 2014 | 03:58 PM
I think I found it:
http://lmgtfy.com/?q=google.com
Biggie_B
May 27, 2025 05:51 PM
SidhuSaaB
May 30, 2020 12:40 AM
Jul 16, 2017 07:33 AM
Rcelestino93
Sep 23, 2015 10:01 PM
