AEM vs. INJEN Cold Air Intake - A retrospect
Old Oct 3, 2005 | 12:26 PM
MichaelBenz's Avatar
CTS-V Import Slayer
Exclamation AEM vs. INJEN Cold Air Intake - A retrospect
Ok guys....heres the skinny (at least as far as my opinion goes) on the Cold Air Intake Systems offered by both Injen as well as AEM. Here's my story...I first got the Injen system as I could not for the life of me figure out why it was so much more expensive than the AEM system, so I figured I would "go the the premium model" as I often tend to do. Got the Injen unit installed and was happy. Then I read in here about how the AEM might be bigger tubing....then I read about how the AEM units have "snapped" and broken (still cant figure that one out)....,ect, ect. There is a little truth to almost everything out there.
#1 - the cost difference - I would say that the Injen unit is made somewhat better than the AEM unit, heavy polished tubing, and somewhat longer than the AEM unit resulting in a lower fit closer to the front grille. You must load the Injen unit from the bottom (wheel well) up as it is so long it will not fit if you try to go top down. The badging on the Injen unit is higher quality too, if that matters to you. The black rubber connection tubes are higher quality on the Injen unit than the AEM....but the AEM has better coolant hose relocation technique...they give you a longer tube to replace...not a splice-in peice like Injen does to just lengthen the existing....BUT...the Injen technique is much easier to install. (AEM gives you a replacement long tube and Injen gives you a nipple piece and a short hose extension with clamps..either way...it works both ways just fine)
#2 - the install difference - the AEM unit has a spot to relocate the oxygen sensor farther down the system, resulting in an additional small horsepower gain...and the Injen unit does not offer this option, retaining its CARB status. The AEM unit will install from the top down as it is somewhat shorter tubing by about 4-6 inches. The AEM unit completely replaces the small coolant line with a longer unit...and the Injen unit just has you lengthen the existing line with a nipple and short hose...either way works...I personally prefer the one peice longer tube though, less chance for leak with less connections. The AEM unit mounts the rubber vibro isolator on the top side under the hood with a bolt/nut that goes through the wheel well area where they have you remove a wire loom - and the Injen unit mounts the exact same type vibro mount lower in the wheel well area in an existing wire tap, where some of the main ground wires are...having you relocate them to a existing hole just like it about three inches away. (no biggie) AEM's was a bit easier as you did not have to relocate any wire grounds...just disconnect a wire loom from the inner wheel well. Both filters are located in the same general area....Injen just gets theirs a bit closer to the front grille area than AEM does, but both intakes seem to get plenty of air where they are. Not a huge difference here...but there is one. The tubing is also about 1/4 inch larger on the AEM unit than the Injen unit, resulting in different types of HP gains....see below.
#3-The test drive. AEM's is definately louder than the Injen unit and makes different power than the Injen unit. The AEM pulls WAY harder off the line than the Injen unit did (I assume because the bigger tubing?). I can actually spin my tires now and get a small burnout mark (on an Automatic yet!).....never did that with the Injen unit. BUT...it felt like the Injen unit made better midrange power right after it got up and going. Injen unit was definately louder than stock....but the AEM is louder than the Injen unit by about 15% or so....and the larger tubing makes a better more agressive sound....just more of what the Injen had. So all in all.....AEM performed better off the line.
#4-Bottom line-Both performed well....but I give the edge to AEM now that I have actually had both of them installed and ran them both on my car. I switched to AEM from the Injen unit due to the additional port for the relocation of the oxy sensor as well as the fact that the tubing is a bit bigger. I figured it had to make better power....and for cheaper too. I replaced the polished unit with the red anodized unit made by AEM....but would probably suggest to stay with the polished, unless you are particularly fruity about the red or blue color. I think the polished units have a more quality finish prone to better longevity and wear. Get the AEM unit if power is your goal....get the Injen unit if you are worried about tire wear or are looking for a good kick in the butt, but not necessarily tire spin type power. This one is definately personal preference. If you like raw dirty power...get the AEM....if you like mild....get the Injen.
Old Oct 3, 2005 | 12:46 PM
legionofdoom's Avatar
Very nice write-up. I'm currently on the fence as far as the AEM CAI...
-LOD
Old Oct 3, 2005 | 01:00 PM
PoochaKannInc's Avatar
Shift_faster
Very nice write-up. Thanks. Now you are making me want the AEM.
Old Oct 3, 2005 | 02:51 PM
CTS-V Import Slayer
Was driving back from lunch today.....lets put it this way....and I think this is pretty accurate.....>before it was better than stock....but now....it has all the air it needs for my specific setup with the larger exhaust, etc. Injen would probably rock like a mutha on stock exhaust...but the AEM provides that little extra bit of air flowthough with the Comptech exhaust installed compared to the Injen. With stock exhaust...maybe the Injen may be better? Dont know as I did the exhaust before intake. (either one)
Old Oct 3, 2005 | 03:26 PM
TheAcAvenger's Avatar
Perfect timing, I was just about to finally about to buy an intake. I was wondering if the Aem you're using was the V1 or the V2?
Old Oct 3, 2005 | 04:36 PM
Teh Jatt's Avatar
The Oracle of Acurazine!
thanx, i'll be getting AEM
Old Oct 3, 2005 | 05:25 PM
CTS-V Import Slayer
There is no V2 for the 2005 model year TL listed yet....I am using AEM part# 21-513.
Old Oct 3, 2005 | 06:11 PM
JDM5lugHatch's Avatar
Now with i-Vtec
Nice write up. Can't wait till my AEM comes in on Thursday. One thing I liked about the Injen over the AEM was the fact that it was available in a black powdercoated finish.
Old Oct 3, 2005 | 07:42 PM
HEK's Avatar
HEK
Team Nighthawk Mambo King
Hope to see pictures guys of your installations or final product, I have a red AEM and I'm dying top see another color besides mine and the polished SS....BTW Good choice...
Old Oct 4, 2005 | 05:20 AM
PiPsToRmPaY's Avatar
Hunting for TL w/ Navi
Great write up~! I'll be saving for AEM~! NOw I really want one~
Old Oct 4, 2005 | 08:48 AM
chill_dog's Avatar
Oderint dum metuant.
Yes, very good write up...makes me glad I got the AEM. Of course, mine's still sitting in the box as my lazy @$$ hasn't put it in yet. I wanted polished, but came across a good deal on a silver one...going to have to paint it black before I install it as I don't really like the silver.
Old Oct 4, 2005 | 10:17 AM
CTS-V Import Slayer
I have not had time to get pics of the new one....and given I did such a write up, it would have been nice to team it with install pics...but honestly....when I am on the jazz and in the install mode....pics during the install are the last thing on my mind. I always thought it would be really cool to do that...but just not geeky enough to think about it when I am working on it. Well....now that I think about it...I guess I did think about it...and the added time it would take to mess with it (given I work alone for the most part) and quickly decided to move on. I do have a finish pic of the Injen...but prob already seen it and it is a top side pic only....
I will work on getting some of the AEM unit too.
Old Oct 4, 2005 | 10:59 AM
Excelerate's Avatar
Former Sponsor
Well I guess I will have to set up a GB for AEM Cold Air Intakes now. I already have one for the Injen but everyone wants AEM so PM me for prices and I will look into an AEM GB.
Old Oct 5, 2005 | 10:55 AM
CTS-V Import Slayer
Damn I hate salespeople (one myself). Thanks for the commercial!
Old Oct 10, 2005 | 04:05 PM
CTS-V Import Slayer
I was just thinking last night about something else that I should have added here....
Wet Driving:
Injen: Never had a problem ever although the intake is somewhat lower and closer to the actual vent opening in the front bumper.
AEM: No problems whatsoever so far and dont expect any either.
BOTH: Dont drive through water more than two inches deep for the most part. And when you do....do so very carefully and drive slow as to NOT throw water into your fender wells! Just chill when it rains and drive with sense and dont tach it up above 2000-2500 to keep the suction factor down too! LET ME REPEAT THAT WATER HAS NEVER BEEN A FACTOR ON EITHER UNIT AND I HAVE TESTED BOTH IN RAINSTORMS. I think you have to really be asking for trouble (like driving through deep water) to have a water intake problem.
Old Oct 10, 2005 | 04:14 PM
flvol77's Avatar
Got Pearl?
Wet Driving:
Drove home from Knoxville Tn to Vero beach, FL last weekend and it rained the entire trip because of TS Tammy and I had Zero Problems. I have the AEM CAI.
Old Oct 10, 2005 | 04:59 PM
Ka0tik's Avatar
is there a ride difference when you are not flooring your car (aem vs. injen vs. stock)?
is there a difference in feel when you are idling (again aem vs injen vs stock)?
what is the difference in mpg (aem vs injen vs stock)?
0-60 time differences and 1/4 mile time differences?
these would be very helpful
Old Oct 10, 2005 | 05:17 PM
CTS-V Import Slayer
When not at WOT.....there isnt much difference. Difference of feel at idle? It is a little louder...that is about it. As for fuel economy.....not gonna make a difference there...other than your driving habits might because you are punching it more now! 1/4 mile time differences....not sure.....I am a "seat of the pants" street driver/tester and have never been out to time at the track....so I am clueless.....I am just giving you my feelings from the "cockpit"!
Old Oct 10, 2005 | 05:26 PM
NFLblitze1's Avatar
Youse Gots Sacked
THANK YOU!!!!! finally....do you think u can beat EBAY PRICES? if so.....youve got a sale!
Old Oct 10, 2005 | 06:06 PM
Scribesoft's Avatar
Aaaarrrggghhhh!
Agreed. If so, you'll probably scarf up those of us who haven't already bought the AEM as customers. I'm assuming there's a good sized group of us in this forum alone who want, but don't have it yet.
Old Oct 11, 2005 | 09:55 PM
Carson89X's Avatar
Open Bar Dude
The AEM sounds like it is for me.....somebody hook me up with a price b/c I got a fever!!
Just picked up a 99TL.....and already looking.....this will never end
Old Oct 11, 2005 | 09:58 PM
NFLblitze1's Avatar
Youse Gots Sacked
i am pretty sure that there are atleast 20 people on this forum who would buy the AEM intake in a group buy if it was less than 190 shipped.....especially because it has such good feedback...and a good price
Old Oct 11, 2005 | 11:03 PM
Ka0tik's Avatar
oh and neither void warranty correct?
Old Oct 12, 2005 | 03:03 AM
Donte99TL's Avatar
Does anyone read this
Is either one of these smog legal?
Old Oct 12, 2005 | 06:31 AM
Scribesoft's Avatar
Aaaarrrggghhhh!
Yup, "shipped" is the key word ..
Old Oct 12, 2005 | 09:47 AM
CTS-V Import Slayer
Yes....both are smog rated out of the box.
Old Oct 12, 2005 | 09:52 AM
CTS-V Import Slayer
Actually...that subject has been beat to death on these boards. There is a law that states that the MFG must PROVE that the mod you did on the car actually caused the problem in question. Most dealers would tell you it is not a big deal....a matter of fact...I have even heard some dealers selling the parts?ie. Acura of Escondido, California on ebay> they sell right out the door too as these are all parts they stock.
I guess the basic answer to your question is no.
Old Oct 13, 2005 | 10:09 AM
user 4529729's Avatar
So.... what's the deal with a group buy? Don't want to go FleaBay route if I don't need to.
Old Oct 13, 2005 | 10:16 AM
Now with i-Vtec
If and when there is a group buy it will be in the " The Black Market" section of the forums. Oh and I got mine from ebay with no problems whats so ever for under $200 shipped to my door. Not to mention I bought from the same company previously with no problems on a very hard to find part at a ridiculously low price.
Old Oct 13, 2005 | 10:28 AM
Scribesoft's Avatar
Aaaarrrggghhhh!
Would you mind sharing the name of the company? If they're a good outfit, I'd like to see what they have.
Old Oct 13, 2005 | 11:25 AM
Beat me to the punch...
Old Oct 14, 2005 | 12:15 PM
CTS-V Import Slayer
I am very proud to tell you that I built most my car from EBAY, good dealers there so long as you stick with the Acura dealers on there
Old Oct 14, 2005 | 12:39 PM
Any one in particular you'd like to share?
Old Oct 14, 2005 | 01:17 PM
chill_dog's Avatar
A of E (Acura of Escondido).
Old Oct 17, 2005 | 12:48 AM
CTS-V Import Slayer
Got most everything from them or Curry Acura (mostly A of E). Have another replacement set of 4 A-spec rims/tires coming this next week as I rashed one of mine very minorly...but cant stand that type of shit so I had to replace. Now I have an extra set of 4 for use in winter or when I take the car to the garage (to save the good ones so they dont screw em up). Also just bought an A-spec steering wheel from AofE.
Old Oct 17, 2005 | 05:18 AM
Now with i-Vtec
Sorry I missed this some how. The company is kurumamotoring (ebaymotors).
Old Oct 17, 2005 | 11:09 AM
CTS-V Import Slayer
wtfsick:
Old Oct 17, 2005 | 11:14 AM
Now with i-Vtec
wtfsick:
They asked a question and I answered it. Grow the FUCK UP!
Old Oct 17, 2005 | 11:32 AM
CTS-V Import Slayer
LOL....GEEZ.....I was just messin with ya dude! I also got my AEM from the same vendor you did.....that or the Injen....cant remember....but, yes...you are right...they are a good vendor! A of E doesnt even sell these, only OEM Acura stuff and Comptech stuff.
Actually....I had thought you were this one dude that has been following me around smashing commercials everywhere soon as you mention a brand name he can sell.....which you are not.....and trust me....I am full grown!
Old Oct 17, 2005 | 11:47 AM
Excelerate's Avatar
Former Sponsor
Guys, I'm working on some numbers right now for a GB.
