Aem bypass valve size
Old Aug 29, 2008 | 12:38 PM
wuiwui85's Avatar
Boosted...
I am buying a AEM CAI and I need to know what size bypass valve do I need this is the part number for AEM CAI 21-513B.
Old Aug 29, 2008 | 01:30 PM
Spiritman's Avatar
Man of God.....
Cool V2? Did someone say V2???
Don't buy the standard AEM intake, now that we have the V2 from AEM put in our TL's!! It's not just the sound of it that's better. It will give you more low/mid range torque. I don't have any dyno numbers. But I have driven both!
Get the V2!!!
Here is the link to the install.
https://acurazine.com/forums/3g-tl-performance-parts-modifications-112/new-mod-v2-intake-big-shout-out-precision-motorspotrs-644834/
Old Aug 29, 2008 | 04:12 PM
csmeance's Avatar
there is no bypass valve for the intake, even if there was one, it's not worth it, I have seen where the foam that it is made of deteriorates over time, then when it breaks apart enough, a chunk flies into your engine and can destroy it. Get the AEM V2 intake
Old Aug 29, 2008 | 09:02 PM
amk6453's Avatar
08 TL Type S
V2 fits TL-S?
Old Aug 29, 2008 | 09:05 PM
o4Komodo's Avatar
Rev High; Drive Happy
^^^^ Where have you been? lol.
Two members so far [that I know of] have succesfully installed the AEM V2.
It's from the Accord... I don't remember what model(s) though.
I believe Stillhere said it was a tight fit and minor work was needed to make it fit.
He has a V1/V2 comparison thread.
Old Aug 30, 2008 | 01:53 AM
stillhere153's Avatar
94 DC4 RS LSV/Turbo
spirit did you get it... installed? I been soooo busy I didnt even think to pm you...
as for the bypass valve... if you must..... if you get the v2 it will be compatible with the 3" diameter bypass valve as the aem v2 is 3" at the top 4" at the bottom... you pretty much can put it anywhere above the elbow....
for the record... CSMEANCE is CORRECTO
Old Sep 2, 2008 | 02:39 PM
Spiritman's Avatar
Man of God.....
Don't use the bypass on the V2.....
That's what AEM said. It will interfer with the power increase you will get with the V2.
I havent had time to even start that yet. Was there a rubber connector in the box? You know, where the bypass would go. Between the TB and the CAI? I didn't see it in the box.....or the clamps.
Old Sep 2, 2008 | 03:09 PM
imj0257's Avatar
Q('.')=O
Originally Posted by csmeance
...it's not worth it, I have seen where the foam that it is made of deteriorates over time, then when it breaks apart enough, a chunk flies into your engine and can destroy it...
lol rgr that.
I had AEM CAI with the bypass valve for my integra back in the day and that shit wore down fast. I actually had to replace it about a year later cus the foam from was all ripped apart and falling off. from then on i didnt give a fuk cus i just traded it in for little $ and got the tl
Mike734
Dec 10, 2021 01:25 PM
tsx_boy
Dec 13, 2019 08:33 PM
Tribalheads
Sep 29, 2015 03:24 PM
shawnafoxx
1G RL (1996-2004)
Sep 28, 2015 12:33 PM
Username 0
2G TSX Performance Parts & Modifications
23
Sep 28, 2015 09:09 AM
