3.7 IM and TB swap issues! Help!
Old May 6, 2019 | 02:12 PM
BEEron_UA7's Avatar
7th Gear
Hello Acurazine, I have a 2008 Type-S AT. Recently did the 3.7 IM+TB swap, AEM CAI, Jpipe w/ hi-flow cat. I used my old 3.5 MAP sensor on the TB. I have the hondata flashpro and set a new calibration. I noticed fluctuating/higher rpm on idle. On the data log, it shows MAP constant at -22. When I run my scan tool, with key on engine off, shows MAP at 14.4lbs. Once the car is on, its showing MAP fluctuations from 3-6lbs. I torqued down the IM bolts, checked all vacuum lines, and all sensors connected. Anyone else have idle issues? Anyone find a solution? Any help is greatly appreciated.
Old May 6, 2019 | 03:51 PM
losiglow's Avatar
Is it throwing any codes?
Old May 9, 2019 | 01:09 AM
BEEron_UA7's Avatar
7th Gear
Sorry been busy with work all week. Havent had the chance to check. After the install did test drives, but noticed when cruising, if rpm drops to 1k or lower, itll keep revving up to 1.5k. I'll be able to scan more later this week. It's been sitting in the garage since the install and test drive.
Old May 9, 2019 | 05:27 AM
perhaps a vacuum leak?
Old May 9, 2019 | 08:39 AM
horseshoez's Avatar
Latent car nut
Have you checked the IACV?
DJMikeT
Feb 21, 2016 01:22 PM
Skunkworkz
1G RL (1996-2004)
Mar 3, 2015 05:57 PM
JORTS
Feb 11, 2009 12:28 PM
trewatts
Feb 21, 2007 09:43 AM
RidinLow
Aug 13, 2001 12:48 AM
