08 tl Type-s turbo
08 tl Type-s turbo
Hey guy KingLouie here
I'm in bit of a predicament I'm a 08 to type s at owner nd I'm wanting to turbo possibly twin turbo I've been looking into supercharger vs turbo nd I'm turbo. I already have some work into my tl nd have the money to spend but that's my issue need some help as parts. Lmk comments plzz
question I’m new on here and still trying to learn this lol was wondering if I can take j35 head and put on my j32 block? If there a difference or what would I needa get/ do for a direct fit
Won't make a difference; in fact, most J35s used the same head as on the J32A3.
The heads are already pretty clean; porting them may open up a few (few as in 'single digits') extra horse power up near redline, but by the same token, you are likely to lose a bit of low to mid range torque due to reduced low-end resonance and turbulence.
thanks for the help!
Sorry bud but the auto power dream doesn't exist in JDM cars. You can go chance 400 hp on a 60le on american cars, but JDM auto trans is safest under 400 if you want any longevity without paying $3000+ to overbuild the transmission.
Stick to NA power, there's a lot of extra power to be had in these cars, especially TL-S, you just can't get it by slapping a turbo on it. You can run a low psi supercharger or turbo, but your power output should be under 400 for an auto, with a cooler, with custom fluid, with mods, with frequently checked and swapped pressure switches.
I'd start with looking up auto transmission maintenance and improvements before you add power. I just killed off my auto to get into a manual, and while I spent a lot of time keeping my auto alive it paid me back every day when I didn't need to use a clutch and dropped power from 3krpm with the brakes on (if you like that sort of thing, i'm reformed). There are pressure switches that when replaced can add longevity, as well as simply swapping the fluid and adding a generic aftermarket transmission cooler/temperature gauge ( I went overkill with the temp gauge), and all those have lead to auto transmissions being used on the AV6 forum to hold up to 400-450HP for a fair amount of miles. Do some searching before asking though, this as well as intake and exhausts are the three most popular posts on the forum, and there's a lot of info. The advanced search tool is a godsend once you figure out all the details and have some time.
There are also tools to adjust the pressures and switches inside the auto transmission. Nobody has officially experimented with this, but if you're going through and replacing everything and trying to really bolster this transmission, and want to gamble with some new tech that could make the transmission better or blow it up, PM me and i'll collect my info. Only AFTER installing every possible upgrade however, just adjusting the pressures can break a worn down transmission or one getting bad signals from bad pressure switches.
PrankParts is worth a google.
