3.2L base TL IM help :/
so i’ve been trying to figure out some more mods I️ can do to my 07 TL (3.2) . I️ came across the 3.5 Intake manifold spacer from the MDX that can be installed with the right bolts, but is there anything on a 3.7 IM spacer that can be bolted on just like the 3.5? sorry i’m new and I️ cant seem to find anything I️ might have missed it?
currently have my resonator and my rear mufflers cut and have a CAI. planning on getting a ktuner after this.
Anything Helps!!!!
Anything Helps!!!!
the only acura that came with the intake manifold spacer is the MDX.
the spacer is the same.
if you dont want to go through the troubles of getting shorter bolts...you can just buy the CNC'd aluminium P2R manifold spacer that comes with the extra hardware for your needs. it's only like $85 bucks.
Former Sponsor
PLUS, the P2R P392 Billet Intake Manifold spacer A) Saves you top end power which can suffer with the MDX spacer (it's really a bit much...designed to optimize response and low-end power) and B) saves you from hood clearance issues.
xxh
08-21-2010 03:56 PM
alexSU
08-02-2010 12:27 PM
jguerra23
03-27-2010 10:10 AM
