'06 CT supercharger install.HELP!
Old Jan 29, 2012 | 08:15 AM
myagi's Avatar
Swampy and I are installing the supercharger and need help tryna figure out what wire to splice into the ECU on a 06 since his instructions are for a 04-05. Need help or any advice ASAP thanks
Old Jan 29, 2012 | 11:47 AM
TLove It!'s Avatar
Superstressed
PM'd you.
Old Jan 29, 2012 | 05:33 PM
myagi's Avatar
Anyone? Sc is installed only need the acm to connect
Old Jan 29, 2012 | 06:10 PM
NAiL05's Avatar
What is it supposed to connect too? I can see if I can look up a wiring diagram at work tomorrow if it will even pull up.
Old Jan 29, 2012 | 06:29 PM
KN_TL's Avatar
Does this help:
Old Jan 29, 2012 | 06:44 PM
myagi's Avatar
On the acm what wire do I splice into?
Old Jan 29, 2012 | 06:47 PM
myagi's Avatar
Let me rephrase that. Using the acm,which wire do i splice into on the ecu?
Old Jan 29, 2012 | 07:01 PM
TLove It!'s Avatar
Superstressed
From the looks of the diagram that KN_TL was nice enough to post, it looks like you need to splice in to the grn/red (map) in connector C. My 2004 used the grn/red (map) from connector D. At this point it might be worth it to be safe and call CT Engineering tomorrow.
Old Jan 29, 2012 | 07:05 PM
handsom-hustla's Avatar
wish i could answer the ? for you, but not 100% sure. call CTE tomorrow, there CS is pretty good and always willing to help.. GL with your build
Old Jan 29, 2012 | 07:11 PM
myagi's Avatar
Thanks guys greatly appreciate the help!
Old Jan 29, 2012 | 07:32 PM
213swampy's Avatar
Dame Jeff sorry wasn't able to help you finish
The install was hoping to see how it was going to run,
But I guest Ill just have to wait and see when cup cake
Meets come around!
Old Jan 29, 2012 | 08:22 PM
myagi's Avatar
Its cool man. You helped me out a lot.still no luck switching the wires hopefully its good to go before I go into work tomm.
Old Jan 29, 2012 | 08:25 PM
213swampy's Avatar
I'm digging through everything looking for that last page man
And can't find it, hoping we can get this running for u tonight
So u can make it to work tmrw!
Old Jan 29, 2012 | 10:56 PM
myagi's Avatar
update: did some research and figured out the connector for 06 was switched got that fixed spliced into connector c #5 pin red/green car starts but idles around 1200-1300 CEL is on vsa and traction..???
Old Jan 30, 2012 | 12:11 AM
NAiL05's Avatar
From what I am reading up it says it monitors the vtec, fuel, and i think timing...usually it comes with a jumper harness apparently so I would see if you can get a hold of one of those instead of going into the stock wires
Old Jan 30, 2012 | 12:34 AM
AckTL05's Avatar
Former Sponsor
All the ACM does is pull more fuel. I hate to sound like a broken record and I am sure its fine right now but for longitivtiy wise there is a lot more needed to run this kit properly. I would defiantly look into an AEM FIC and get a proper tune, two step colder spark plugs and larger injectors.
If you still want to hook up that ACM, you only connect one wire, not both. I will try and find it, but I haven't had that in my car for years so I can't look sorry. I remember seeing some threads on them and I will try and find those as well.
Old Jan 30, 2012 | 01:02 AM
libert69's Avatar
18psi
save yourself and your motor....lose the ACM and grab a FIC. Or better yet, get JandR's ms3 ecu. Ill tell you the difference between FIC and ms3 is night and day. So much more control over your motor.
Old Jan 30, 2012 | 10:27 AM
myagi's Avatar
I'm planning on getting the j and r ecu down the road for sure but I just wanna get the acm working right now so I can drive my car.
the acm has a green and white wire that's open .I splice into the map wire and green goes to ecu and white to motor?
BoricuaTL
Apr 8, 2016 01:08 PM
Joe Avesyan
Sep 29, 2015 03:57 PM
k6biv
Sep 22, 2015 02:06 PM
2G-TL-Type-S-03
Sep 20, 2015 12:48 AM
simplyjayyy
2G TSX Performance Parts & Modifications
Sep 2, 2015 12:57 PM
