XM to Sirius...
Old Feb 21, 2009 | 08:32 PM
bimmerman's Avatar
Traveling the country
XM to Sirius...
I tried to search, but it appears it is broken.
What would it take to swap out the XM unit for a Sirius one? I want to use Sirius instead of XM and have it play through the stock headunit like the XM does currently.
It is possible?
Old Feb 21, 2009 | 08:58 PM
RACINGHART03's Avatar
Huh? Do you mean can you switch the XM receiver out for a sirius version? If so I would say no. The XM control unit is made specifically for the tl.
Old Feb 21, 2009 | 09:46 PM
csmeance's Avatar
It is possible?
There are two modules that you would need to use. the modules are:
HONSC1: Honda/Acura XM-to-Sirius Adapter
SiriusConnect Universal Vehicle Tuner SC-C1
Old Feb 21, 2009 | 09:58 PM
bimmerman's Avatar
So if I buy both of those that is all, if so that is cool. Is there not a way to reuse the stock XM antenna? I really would rather do that than run the Sirius antenna. If not can the antenna be mounted on the back deck or something like that?
Old Feb 21, 2009 | 10:11 PM
bimmerman's Avatar
Found out how to use the stock antenna. TSS want $90.00 for that adaptor, that is just crazy, might just forget about it.
Old Feb 21, 2009 | 11:18 PM
bimmerman's Avatar
Anyone have a link to a thread, or can tell me where the large XM box is?
Old Feb 22, 2009 | 12:25 AM
GeezerB's Avatar
What could you possible need from Sirius that isn't available from XM? All the premium stations are available for a fee. This request is nothing but silly.
Old Feb 22, 2009 | 01:11 AM
bimmerman's Avatar
Why would I want to pay $17.00 per month when the only reason I want Sirius is Howard and Bubba?
I have a Stiletto 2 that has a lifetime subscription I bought off of CL for $75 so I really need to swap over.
I just went out to the garage and spliced into the factory XM antenna harness and connected it to the cable I cut from my home dock and ran it to inside the center console it and it picks up great!
No I have to figure out what to do about power and something to hold the Stiletto.
Old Feb 22, 2009 | 09:56 AM
If you wanna keep it hidden in your console you can t off from the acc power socket wiring. White with red/white wire if I am not mistaken. That will give you power when you want it. You can use the black wire for the ground too.
Old Feb 22, 2009 | 10:20 AM
bimmerman's Avatar
I just ordered a car charger for my Stiletto and I am going to hard wire it in under the console and run the wire in the same holes and the antenna wire. No I have to figure a way to input it into the radio with out using the tape adapter.
vinnier6
Jan 22, 2008 07:51 PM
RonnyC
Dec 8, 2006 10:48 AM
