Xm radio problem
Old Oct 27, 2005 | 06:50 PM
jazzyjg24's Avatar
Xm radio problem
So I have done a search and come up empty. When I attempt to listen to xm and try and select one of my presets it says it is "updating" and will not select the station i choose. If I use the scroll knob it only scrolls to about 5 random stations. Any ideas on whats going on here
Old Oct 27, 2005 | 06:52 PM
NFLblitze1's Avatar
Youse Gots Sacked
is this a constant problem or occasional? try disconnecting the battery....but have ur NAVIGATION and RADIO CODES handy
Old Oct 27, 2005 | 06:59 PM
jazzyjg24's Avatar
This is the first time this has happened drove home from work last night and things were working fine. Got in the car this morning and thats when i noticed it
Old Oct 27, 2005 | 07:18 PM
NFLblitze1's Avatar
Youse Gots Sacked
does it still continuously happen?
Old Oct 27, 2005 | 07:26 PM
jazzyjg24's Avatar
yes it has continously happened sense this morning
Old Oct 27, 2005 | 07:28 PM
NFLblitze1's Avatar
Youse Gots Sacked
try disconnecting the battery like i mentioned before...usually that fixes most electrical glitches or freezes
Old Oct 27, 2005 | 08:21 PM
jazzyjg24's Avatar
disconnected battery and still no luck
Old Oct 27, 2005 | 08:22 PM
NFLblitze1's Avatar
Youse Gots Sacked
did u let it settle for like 10 minutes....sometimes time is a factor...if not it might be a hardware problem....or a software glitch...if u disconnected the battery and left i for like 10-30 minutes...and u come back and it still dosn't work...then call the dealer
Old Oct 27, 2005 | 08:52 PM
jazzyjg24's Avatar
ill try that thanks for your help
Old Oct 27, 2005 | 10:50 PM
nfnsquared's Avatar
It's scrolling through the presets. If I remember correctly, you have to change from the "Catergory" setting to the "Channel" setting ( a CH will appear in the display).
It's in the manual, in case I've got it backwards.
Old Nov 4, 2005 | 10:06 AM
FinsUp328's Avatar
I encountered a similar issue about a month ago. However, I found out that one of the stations that I chose as a preset no longer exists.
Old Nov 18, 2005 | 03:28 PM
hobbes1's Avatar
Problem resolution
This also happen to me. Some of the channels disappear.
I called xm Radio (1-800-967-2346) and they refreshed my radio.
You have to sit in you car and tune the radio to channel 1 for about 15-20 min. for it to refresh.
All the missing channels are back!!!
Old Nov 25, 2005 | 07:32 PM
calcbert's Avatar
You can also get your radio ID (displayed while you're on channel 0) and type it in to http://www.xmradio.com/refresh/ . Then the satellite will broadcast your update signal for about a day.
SidhuSaaB
May 30, 2020 12:40 AM
Puma Jim
20
Oct 20, 2016 11:59 AM
Kres43
1G RDX (2007-2012)
Oct 3, 2015 07:16 PM
tristann616
1/2G MDX (2001-2013)
Sep 22, 2015 11:40 PM
vanderveen44
ILX
Sep 16, 2015 10:51 AM
