Will this work? iSimple Gateway
Old Jun 6, 2014 | 10:57 AM
HelpNeeded's Avatar
5th Gear
Hello all
Will this work for a 2006 acura TL and is it good? The car has no aux input so I would like to add this to put an aux in.
http://www.amazon.com/iSimple-ISHD571-Gateway-Automotive-Interface/dp/B00455IS1O/ref=sr_1_20?s=electronics&ie=UTF8&qid=1402057761&sr=1-20 http://www.amazon.com/iSimple-ISHD571-Gateway-Automotive-Interface/dp/B00455IS1O/ref=sr_1_20?s=electronics&ie=UTF8&qid=1402057761&sr=1-20
Old Jun 6, 2014 | 11:10 AM
imakeholesinu's Avatar
Welcome to Acurazine. You should check out the Audio, Bluetooth, Electronics and Navigation Forum or use the search feature.
That should work if you have an XM button in your car.
Old Jun 6, 2014 | 11:49 AM
buzzkill911's Avatar
I looked into the iSimple too. Then I went to a local mobile electronics installer and they told me about an FM modulator you can use instead which is what I went with.
Basically they installed a power switch hidden well inside the cup holder of the center console. When I switch it on I can play my iPod or any mobile device through an FM station when the audio source is plugged into the headphone jack the audio guys installed too. The advantage is that it works through the headphone plug which is universal instead of device specific plugs. Also, this leaves my XM button alone because I still listen to that too. Finally, the FM modulator was cheaper than the iSimple too.
It's been a while since I had it installed so I don't have a manufacturer, model number or exact cost. But it's been working well and I'd suggest looking into it. But like said above, if you go to the Audio section of the 3G garage you'll see people are pretty happy with the iSimple too.
Old Jun 6, 2014 | 11:55 AM
To clarify further, (and I apologize if I'm insulting anyone's intelligence but I didn't even know about this product) an FM modulator is different from an FM transmitter.
A transmitter usually powers through a cigarette lighter and broadcasts an FM signal which your radio picks up. This is a lower quality audio broadcast.
The modulator actually plugs into the rear of the radio where the FM antenna plugs in. This means the modulator totally overrides any over the air FM broadcasts because the modulator feeds right into the FM antenna which is also much better audio quality than an FM transmitter.
Hope this helps and good luck!
Old Jun 6, 2014 | 12:04 PM
I don't know if this is the exact one I have, but this is what I'm talking about above:
Amazon.com: Scosche FM-MOD02 Universal Audio Input FM Modulator for iPod, Satellite Radio or Portable Music Player: MP3 Players & Accessories Amazon.com: Scosche FM-MOD02 Universal Audio Input FM Modulator for iPod, Satellite Radio or Portable Music Player: MP3 Players & Accessories
Old Jun 6, 2014 | 12:10 PM
erdoc48's Avatar
06 Anthracite TL
I'm actually surprised a stereo installer would recommend an FM modulator vs. a regular iPod interface like an iSimple, USA Spec, or Grom. How is the sound quality with the FM modulator?
Old Jun 6, 2014 | 12:17 PM
ntmera's Avatar
I've got that iSimple Gateway hooked up in my car. It's perfect!
I too am surprised that a shop would recommend installing a FM modulator over the iSimple system, but I'm guessing you said to them that you want to keep your XM and that was an unknown for the shop. The iSimple Gateway will provide better sound quality than the FM modulator.
The iSimple comes with both a regular headphone jack input, and an iPod 30pin input. I use a 30pin to thunderbolt adapter for my iPhone, and the steering wheel controls/song information display all work flawlessly. When installed, you will press the XM button and use the right side dial to select between XM/iPod/Aux1/Aux2. XM is left intact - this is simply an add on.
Old Jun 6, 2014 | 12:25 PM
flyromeo3's Avatar
Believe it or not, but FM modulators have come a long way and have improved in quality.
However, nothing beats a wired connection.
Not sure why the installer would recommend. Maybe this one is from the future?
Old Jun 6, 2014 | 12:46 PM
HelpNeeded's Avatar
5th Gear
So an Fm modulator or that Isimple one?
Old Jun 6, 2014 | 12:52 PM
I had an iSimple in my 06. Loved it but I wished I had a cable ran to reset it. Worked like a dream.
Old Jun 6, 2014 | 04:18 PM
pohljm's Avatar
mine works excellent in my 06
Old Jun 6, 2014 | 08:25 PM
Due_Diligence's Avatar
Just get the iSimple and call it a day. Seriously can't go wrong with this product, I love mine.
Old Jun 17, 2014 | 02:37 PM
raidertrh's Avatar
I also just got that ISimple unit installed in my '06. I had them install a female 3.5mm connector in the deep well under the armrest. From there, I just use a short cable to connect from my Android phone's headphone jack to that connector. I select a couple of buttons on the stereo unit to engage it and out the music comes. Way cool.
Old Jun 18, 2014 | 10:34 PM
sickwitit's Avatar
It doesn't come with a factory reset switch?
Old Jun 22, 2014 | 05:08 PM
No it does not come with a switch. You need to follow this link to reset it. Www.pac-audio.com/reset to the pdf that explains how to reset it.
Old Jul 12, 2014 | 11:40 PM
m015094's Avatar
I installed the iSimple ISHD571 in a 2004 TL without NAV. Had the iPod mini hooked up to it and the iPod would not turn off or auto-pause when the engine was turned off - even after a few minutes. I'm not sure why. I've seen a few people mention this in the past about the iSimple although nobody has said it really drained their battery much. Anyway, I was still worried about it draining the battery, so it came out and a different brand went in (USASPEC).
Does yours turn off when the car is off?
Old Jul 13, 2014 | 01:17 AM
bluescreenofdeath's Avatar
No, and it's never been an issue as far as battery drain as least for me
Old Jul 13, 2014 | 08:57 PM
DiamondJoeQuimby's Avatar
Codename Duchess
Uh, no. If anything, they've gotten worse because the FCC limits broadcast strength on them now.
Old Aug 2, 2014 | 10:35 PM
mikee_boy's Avatar
Hey guys, I've been using the Isimple Gateway for a good 3 years now and it's been working perfectly up until I upgraded my iphone from the 4 to the 5s. I bought the lightning to 30pin adapter and now my steering wheel controls won't work and neither does my car recognize my iphone. It still charges my phone though. Any thoughts guys? I went to BestBuy where I got it installed a couple years ago, and the tech there said "oh, that's been a common issue" and said I was pretty much "shit outta luck". Is he right?
Old Aug 3, 2014 | 11:51 AM
pohljm's Avatar
Sounds like you just need to do a hard reset on the iSimple and then it should recognize the phone.
mada51589
Jan 9, 2025 04:40 PM
bymotion
Nov 18, 2015 11:28 AM
acurajj
Sep 19, 2015 03:47 PM
Vejey Gandier
Sep 12, 2015 08:59 PM
ahsm
Sep 9, 2015 08:35 AM
