Will this amp work??
Old Jan 24, 2013 | 10:06 AM
thedeadmanx's Avatar
Will this amp work in my 04' Acura TL if I splice into the line before the factory amp and NOT have to put a line booster in as well? Will this give me the proper bass to the sub?
JL Audio 500/1v2 Monoblock Amplifier 500 W Slash Amp
Preamp Output: 2-channel (independent active filter, parallel with amp filter or pass through)
Infrasonic Filter: Fully-variable 24dB/octave from 15-60 Hz
Signal-Sensing Turn-On: Permits operation without remote lead
Dual mono speaker output connections: Accept up to 8 AWG wire; +12V and Ground connections: Accept up to 4 AWG wire
S/N Ratio: >95dB below rated power (A-weighted, 20 Hz - 20 kHz noise bandwidth)
Old Jan 24, 2013 | 10:21 AM
Gregerst's Avatar
That amp will work fine. It basically has a high quality line driver built into it. If you're going to use the preamp signal you should set the Input Voltage on the amp to Low.
mada51589
Jan 9, 2025 04:40 PM
AndrewS
19
Mar 14, 2024 06:59 PM
acurajj
Sep 19, 2015 03:47 PM
Pegon95
Sep 15, 2015 01:54 PM
yahelou
Sep 6, 2015 09:12 PM
