Will this amp work??
Will this amp work in my 04' Acura TL if I splice into the line before the factory amp and NOT have to put a line booster in as well? Will this give me the proper bass to the sub?
JL Audio 500/1v2 Monoblock Amplifier 500 W Slash Amp
Preamp Output: 2-channel (independent active filter, parallel with amp filter or pass through)
Infrasonic Filter: Fully-variable 24dB/octave from 15-60 Hz
Signal-Sensing Turn-On: Permits operation without remote lead
Dual mono speaker output connections: Accept up to 8 AWG wire; +12V and Ground connections: Accept up to 4 AWG wire
S/N Ratio: >95dB below rated power (A-weighted, 20 Hz - 20 kHz noise bandwidth)
thedeadmanx (01-26-2013)
AndrewS
19
03-14-2024 06:59 PM
mada51589
05-03-2022 08:54 PM
Pegon95
09-15-2015 01:54 PM
yahelou
09-06-2015 09:12 PM
