Weird issue with the navi screen today
Today I stopped for gas, and when I restarted the car, the navi screen was extremely dim.
It showed the moving map just fine (although super-dim), but the touchscreen was inop. I have Angrydad's OK button bypass installed.
I turned the car off and restarted it, and now all is well. Anyone else have this problem?
Nav screen flicker
I had the same issue. It happened a few times without a trend. Dealer "could not recreate". It stopped a week after it started. Maybe was due to solar flares made me mad as he^^ though. 6000 miles 2006 tl
did you turn the headlights on or off??? if so, the headlight switch has a feture so when the gauges are set 1 under max, when the headlights are on, it will dim the lights, but when off, return them to a normal state.
Originally Posted by drmwvr
Was it cold outside? Mine seems to do this when it is cold.
Maybe that was it...it was cold, and the car sat for about a week without being driven before this incident. All is fine now!
Luckily the dash lights (probably white LEDs) and the HIDs work better than that!
The first few times this happened to me, I thought it was the bright-dim thing (MAX button not pressed while headlights on). It's really hard to see on a cold sunny day with sunglasses on.
You can try running the heater on BI-level to run some hot air passed the screen, instead of auto which seems to run thru the defroster/windshield.
gimme a 4G !!
Liquid Crystal Displays tend to show dim at first in colder weather.
I have a 38" Sony LCD tv outside under my patio and when its cold outside, its takes about 3 or 4 minutes for it to show at full brightness, but never when during warmer weather.
My navi screen tends to do the same anytime under 50 degrees or so.
Terminex
It is the cold
It is an LCD issue. It happens on all of the LCD's in my vehicles. You can also see it if you ever leave a PDA or laptop in a car overnight in the winter.
Gianni Formica
09-07-2015 08:28 PM
yahelou
09-06-2015 09:12 PM
SUPRMN84
09-02-2015 11:50 PM
