Voice Recognition Problems after using HFL...
Old Dec 15, 2005 | 07:48 AM
stardient's Avatar
7th Gear
I hope someone can help me, ocassionally after I hang up the phone via HFL, I issued another voicemail command to change the CD. However as soon as I press the voicecommand button, the screen said something like Nav. Recognition not possbile while other system is using the audio system. Then I realized that I am still in "Phone" mode even tho I have hang up and the CD is playing. I tried to make another call and then hang up hoping it would reset, but it didn't. I had to shut down the car so it will allow the system to reboot. What happened? Do I need to 'reboot' everytime when that happens? I also getting a lot of drop outs, after I say "yes" to dial the number I have input via HFL, then after like 20 secs, it then says, "Bluetooth connection to xxxx has been lost". How annoying! Anyone encountered these problems I described above? How do I fix/solve these problems?
Old Dec 15, 2005 | 08:55 AM
acuranewbie's Avatar
I had a similar problem, if I recall I had tro press the hang-up button on the wheel again (even though the call had already ended)
Old Dec 15, 2005 | 10:30 AM
stardient's Avatar
7th Gear
I tried to press hang-up button many times, no luck. I had to shut the car off to reboot the system. Very annoying. When that happens, I can't select any of the Audio functions ie. disc repeat, shuffle, bass adjustments...etc. Nothing.
Old Dec 15, 2005 | 11:40 AM
Hmm that sucks, your problem is way more serious than mine then, hopefully someone here has a clue how to help
SidhuSaaB
May 30, 2020 12:40 AM
12vancover
Oct 16, 2015 12:04 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
95oRANGEcRUSH
Sep 25, 2015 12:50 PM
MikeJM310
Sep 24, 2015 07:24 PM
