Vocie Control for Temp--doesnt work??
Old Feb 15, 2005 | 12:22 PM
Drago's Avatar
Hi guys, I was playing around with the voice controls and very time I put forth a command to set the temp to x degrees C, it never works it always goes 88degrees F or something...this is a CDN car, is there something I need to adjust???
thanks...
D.
Old Feb 15, 2005 | 12:32 PM
Canadian Mike's Avatar
Your car must be set up in the US mode. When I recived mine the dealer forgot to set it to the Canadian mode.
Go to the setup menu (hold the map-menu-cancel buttons all together for 5 seconds) then go into navi region. Set it to Canada not U.S.
Old Feb 15, 2005 | 07:56 PM
Drago's Avatar
Hi, thanks for the response, I gave it shot I think it is Can set, when I go to the help screen under temp. the options it gives me is Farenhiet only, 55-87 or something, is there somewhere else i need to make the adjustment??? Does yours display this in C on the help screen???
Thanks in advance...
Old Feb 15, 2005 | 09:25 PM
This should work, I'm not sure if you went to the right menu. When you have the map on hold all 3 buttons at the same time for about 5sec. Then you will go into a hidden menu. Hit Navi system top left. The system will check itself, if it has an XM box that it trys to check it's on U.S. mode this box will stay red. Then you can hit a button on the far right it should say (can. region) That will switch it over.
If the car is saying temp. in F then I'm sure it's in the U.S. mode
mada51589
Jan 9, 2025 04:40 PM
Feb 25, 2020 09:57 AM
cycdaniel
Dec 17, 2019 10:58 AM
acurajj
Sep 19, 2015 03:47 PM
ahsm
Sep 9, 2015 08:35 AM
