V3 Razr Help
Old Jan 19, 2006 | 08:38 PM
2005BLACKTL's Avatar
6th Gear
V3 Razr Help
I have searched the forum and have not found anything similar, so hopefully someone can help. I have successfully paired the phone. I can dial using the phonebook in HFL and answer incoming calls fine. However, when I dial a number using the phone, I have to use the HFL transfer function otherwise the call stays in the phone....i.e. does not transfer automatically to the HFL. Is there a way to make this happen automatically?
Any help would be appreciated.
Old Jan 19, 2006 | 09:06 PM
JoganJani's Avatar
never stops!
I think that is how it should work. If you initiate a call from handset it will stay there unless you transfer it.
Old Jan 19, 2006 | 09:52 PM
TheNip73's Avatar
Overlord - Team Abyss
I think you might be able to press the call button on the car and then dial on the phone and have it automatically transfer, but I'm not sure. Give it a try next time.
Old Jan 20, 2006 | 11:19 AM
6th Gear
Thanks...I'll try that next time I make a call.
Old Jan 20, 2006 | 06:53 PM
6th Gear
Well, I tried pressing the call button and dialing via the phone...no luck. It did not automatically transfer to the car. Any other thoughts or phone settings I should try?
Old Jan 21, 2006 | 12:05 PM
chasieboy's Avatar
its not gonna transfer automatically until you press talk button and when you hear the beep then transfer..
Old Jan 22, 2006 | 10:16 PM
iTISTIC's Avatar
On the V3C after you hit send and the phone says "connected" you can hit the top-left menu button (for Options) and select "Switch Audio". If your phone is paired properly it will transfer to the HFL. I do this with mine all the time.
Old Jan 23, 2006 | 01:57 PM
Mr Bigglesworth's Avatar
Dude, just press the phone icon on your steering wheel and say "transfer". It will work.
Old Jan 23, 2006 | 09:45 PM
revo1059's Avatar
7th Gear
IIRC I had the same problem when I got mine. On mine I had to turn Auto Handsfree to ON and that solved the problem. Works perfectly now
MENU--> SETTINGS-->CAR SETTINGS-->AUTO HANDSFREE=ON
Try that.
Old Jan 24, 2006 | 08:04 PM
6th Gear
Thanks...I'll give it a try.
Old Jan 24, 2006 | 09:15 PM
ITL's Avatar
ITL
I do my own work.
did it work?
Old Jan 26, 2006 | 07:38 PM
6th Gear
No luck. I have not been successful at getting it to automatically transfering to the car. Other ideas?
Old Jan 26, 2006 | 10:39 PM
iTISTIC's Avatar
There is no way any of us are aware of to get it to automatically transfer. You can do it by going to options on the phone as I described above after initiating the call from the phone, or you can do it by issuing the TRANSFER command to HFL.
bimmer88
Technology
15
Nov 4, 2005 09:25 AM
stangg172004
Technology
Oct 4, 2005 03:29 PM
