V3 Razr Help
V3 Razr Help
I have searched the forum and have not found anything similar, so hopefully someone can help. I have successfully paired the phone. I can dial using the phonebook in HFL and answer incoming calls fine. However, when I dial a number using the phone, I have to use the HFL transfer function otherwise the call stays in the phone....i.e. does not transfer automatically to the HFL. Is there a way to make this happen automatically?
Any help would be appreciated.
On the V3C after you hit send and the phone says "connected" you can hit the top-left menu button (for Options) and select "Switch Audio". If your phone is paired properly it will transfer to the HFL. I do this with mine all the time.
IIRC I had the same problem when I got mine. On mine I had to turn Auto Handsfree to ON and that solved the problem. Works perfectly now
MENU--> SETTINGS-->CAR SETTINGS-->AUTO HANDSFREE=ON
Try that.
Try that.
There is no way any of us are aware of to get it to automatically transfer. You can do it by going to options on the phone as I described above after initiating the call from the phone, or you can do it by issuing the TRANSFER command to HFL.
bimmer88
Technology
15
Nov 4, 2005 09:25 AM
