v3.30F NAVI HACK
v3.30F NAVI HACK
Please bear with me. I didn't make it past 3rd Grade.
For the NAVI hack we have to use a newly created burn disk with the hack files? And we run off our navigation of the new burned disk?
Or are we uploading a new NAVI hack disk -- a CD-R or DVD-R to the NAVI Ram Drive? And using the OEM NAVI Disk?
If you mess up how to default to factory settings?
I have v3.30F
https://acurazine.com/forums/showpos...0&postcount=32
I partially understand this post. ^^^^^
v3.40 files will work for 3.30....
I downloaded cebin. I cant figure out how to use it. When I click on cebin application a minimzed dos screen momentarily flashes then disappears.
I have v3.30F
:what:
There are several threads with step by step instructions. You are burning a disk with just a few hacked files on it. You load the cd with these files onto the navi to install the hacked files, then you put in your acura navi disk and let it load.
TerpNation (09-18-2012)
ANd I cant figure it out
https://acurazine.com/forums/3g-tl-audio-bluetooth-electronics-navigation-94/navigation-hack-guide-welcome-screen-mod-trip-computer-ok-button-nag-removal-604912/
Since I now know we are downloading hacks to the RAM.
If I upgrade to the latest NAVI disk then these hacks will not work?
How do you clear out the RAM to default settings?
:what:
The hack for ver 3.7 or later will work for the newer disk. You will need the older files. If you can find them for 3.0 or 3.4 they should work.
You disconnect the battery for 30 min or longer to reset the navi.
The actual hack process is almost identical on all disk versions. You are just using different hack files. You can take a pick of any of the hack threads and just read....you will learn a ton. Even if it isnt for your exact version.
08_UA7_Gr33k
02-11-2016 02:17 PM
lanechanger
10-13-2015 10:56 AM
SUPRMN84
10-07-2015 09:46 PM
