USB adapter on Stock 2007 Base Acura TL (non Nav)
Is there some type of USB adapter for Stock 2007 Base Acura TL (non Nav), also I've seen this product
But I'm not sure if it will work on my car, any suggestion???
Amazon.com: USB Female to AUX 3.5mm Male Jack Plug Audio Converter Adapter Data Charge Cable: Electronics
while reading the ad:
our car does not have any thing called U disk.
nor is there any interface that can control mp3s.
butt, for 6 bux plus shipping, it doesnt hurt to try.
buy it. try it. and report back to us, you guinea pig, you.
Attention:
1.Make sure your car stereo support AUX decoding.
2.Need aux interfaces, and supports aux decoding.
3.Only support U disk reads mp3 format music.Do not support cell phone, mp3, ipod.
4.U disk capacity is best not too large.
5.U disk do not inside other files and do not have to build a folder,Download songs in MP3 format to use.
6.Our product quality is no problem,Please note that the above points before you buy it.Thank you.
huguin03 (07-07-2014)
Unfortunately the aux in jack is just a standard audio jack and will require some kind of module to interpret the data from your flash drive. The iSimple Connect will give you the feature you desire and more but will cost quite a bit more then then cable you were looking at.
Soul_Deamon
11-13-2018 04:44 PM
handsom-hustla
11-13-2015 05:04 PM
