Update Nav DVD? Worth it?
Old Apr 30, 2014 | 11:52 AM
dynodonkey's Avatar
Got a letter from acura a little while ago offering the Nav dvd update for $99. I have an 05 tl and am assuming it has never been updated. Is it worth the hundo?
Old Apr 30, 2014 | 12:25 PM
JTS97Z28's Avatar
Yes. A lot has changed since 04 or 05 or whenever that disc was made.
Old Apr 30, 2014 | 12:26 PM
truonghthe's Avatar
I you had not update for 2 years then yes its the time.
Old Apr 30, 2014 | 04:23 PM
robocam's Avatar
Doesn't that depend on where you live and how much you use it? I've been using the stock disc that came with my 06, and it gets me where I need to go. I rarely use it though.
Old Apr 30, 2014 | 06:17 PM
Steven Bell's Avatar
Do it.....besides, it's a good price.
Old Apr 30, 2014 | 06:39 PM
DuoDSG's Avatar
Make it so
Thumbs up
I would do it regardless. Not only is it a killer price, but this is the last update EVER for the Orange disc (the one your TL uses).
Even if you're in an area where there are no updates, it makes your navi much more useful for long road trips. Although my phone's GPS is quicker, has more results, etc, I still prefer to use my TL's navi since it's built-in, doesn't suffer from cell service outages like my phone can, and plus it keeps my phone battery from getting used up while I drive from running its GPS.
ESPECIALLY if it's never been updated, you should definitely get the new update. A lot has changed since then (a lot changed for me between this new one-2014-and 2012, which was the last update I had for my navi).
Old Apr 30, 2014 | 07:01 PM
JTS97Z28's Avatar
Also, not that you will necessarily notice a difference, but I believe there are firmware or software updates within these nav disc updates as well. So not only would you be updating your mapping, stores, and whatever else, you will be updating your navi system to the latest software. I could be wrong about this but I think thats correct.
Even if you dont use the actual nav feature often, its nice to know that everything is up to date.
Old May 1, 2014 | 12:18 AM
Will Y.'s Avatar
Registered but harmless
Yes-- there was some updating of the software in '08 and '09 that made the Navi routing a little faster and adjusted the auto setting for Daylight Savings Time.
...I believe there are firmware or software updates within these nav disc updates as well. So not only would you be updating your mapping, stores, and whatever else, you will be updating your navi system to the latest software.
I think the software update stopped after 2009-- no new software loaded from the current disc to supplement my prior 3.80 version.
The 3.80 downloaded quite a bit of software to overwrite the 3.40 version that came with the new 2005 TL.
Old May 1, 2014 | 12:41 AM
FamilyGuy's Avatar
Correct. My 2013 disc updated the firmware on my 07 TL as well as the maps. I dont know if this one will do that, but I'd say theres a good chance it has some updates if it's been that long.
Old May 1, 2014 | 08:51 AM
1995hoo's Avatar
Keep Right Except to Pass
I have the 3.A0 orange disc sitting around doing nothing. I believe that was the 2011 update since 2014 is 3.D0. It's in the 2014 disc's sleeve simply to protect it. If someone wants it, PM me and we can work a deal for postage. I see no reason to charge anyone for the disc because it's useless to me as it is. (Won't be able to send it until next week, however.)
Old May 1, 2014 | 11:06 AM
Spyro235's Avatar
pm'ed!
Old May 2, 2014 | 11:48 AM
jsp62's Avatar
I wonder if there are other generous people in the market forums that would be willing to do this! I just got my first Acura (3G) and love it!
Old May 2, 2014 | 01:47 PM
Dryden311's Avatar
3rd Gear
I would like to update mine aswell, maybe spyro235 can keep the generosity going and pass the disc along to after he's done? lol worth a shot.
Old May 2, 2014 | 07:22 PM
HBK's Avatar
HBK
Which ones do you need? I no longer need the ones in my 08 one.
Old May 5, 2014 | 01:56 PM
1995hoo's Avatar
Both my old discs have been claimed and are on the way to the people who claimed them.
Old May 5, 2014 | 03:27 PM
pohljm's Avatar
Will the original nag screen and splash screen hack work for the updated disc or will I need to create another disc with a different hack?
Old May 7, 2014 | 03:05 PM
aameghoo's Avatar
would like some input on this as well
Old May 7, 2014 | 09:36 PM
Not sure if it will work, but the disc is worth getting.
Old May 28, 2014 | 02:02 PM
mbrula's Avatar
6th Gear
Dumb Question(s), I just ordered the 2014 White DVD Map Update v4.CO for my 2008 Acura TL (first ever update). Can I install myself or do I need to go to the dealer, are there any secrets I need to know to self install? Will I keep all my past destinations that were in the system before the update? Thanks for any help.
Old May 28, 2014 | 03:02 PM
Will Y.'s Avatar
You can install the DVD yourself-- the DVD box has the simple removal and install instructions printed on it.
However, the previous destinations were wiped out when I installed the white disc in my 2005, so I assume your previous destinations will be wiped as well.
The Navi will retain all the "user" addresses, though (like home, dry cleaners, work, etc. that you might have put in for User 1 and/or User 2).
Old May 28, 2014 | 11:49 PM
GOOSEej's Avatar
so the new 2014 White DVD Map Update v4.CO is worth buying? I have a 08 TL but i dont know what version my current system is on.
any help?
Old May 29, 2014 | 01:32 AM
Will Y.'s Avatar
Originally Posted by Will Y.
However, the previous destinations were wiped out when I installed the white disc in my 2005...
I meant "orange disc," not "white disc": it's the orange Navi DVD for '04-'06, and the white DVD for '07-'08.
Push the "Setup" button (to the left of the Navi joystick) and select tab 4 on the screen to get the Navi DVD database date.
For SoCal, there's probably not a huge difference in databases from 2011 to the present 2013 database on the 2014 discs.
Welcome to AZ.
Old Jun 5, 2014 | 10:03 AM
Spyro235's Avatar
Don't I need the disc to run it? I never took the disc back out, and I'm gointvtobtryvto hack it this weekend. If credible people tell me after I update it I don't need it, then I'll happily pass it along after I know my hack is fully functional. Don't want to be stuck without the disc to reset my nav.
Jul 16, 2017 07:33 AM
iesu3423
Sep 29, 2015 08:04 AM
thegipper
Sep 28, 2015 01:01 PM
RadiantCycles
ZDX
Sep 26, 2015 09:18 PM
