Update: Major fail
Old Dec 23, 2011 | 01:43 PM
deantl's Avatar
Update: Major fail
Guess it is the system player causing the error after all...
Old Dec 23, 2011 | 02:01 PM
Trunk Monkey's Avatar
Coolest A-zine Member
It sucks, trust me. But consider yourself fortunate at some degree that it's a $160ish fix and not a $2,000 fix. And one that doesn't require a ton of work to remove/replace. I'll be sending mine out after the 1st of the year
Old Dec 23, 2011 | 03:53 PM
KN_TL's Avatar
try using one of the spinning scratch removers.
nice coin purse you have there
Old Dec 23, 2011 | 05:16 PM
Even if he removed the scratches, the actual nav. drive is what's scratching. It'll just keep doing it. I assume they'll replace the disc or make it work perfectly when you send it in.
Oh yeah....
Old Dec 23, 2011 | 05:41 PM
A SiQ TL's Avatar
There's something you don't read in every thread.
Old Dec 23, 2011 | 10:07 PM
deantl's Avatar
Ha I know, thanks.
Anyways..
I got the ISO for the 2012 white disk, and I burned it to my DVDR discs and, its fixed. Yeah, the disk may go out every 8 months or so but its better then going to Acura for 800 bucks or sending it to the navi company. (My system scratches the disk) Who puts a navi dvd player above a tire? Seriously..
If anyone has Disc problems..
MSG me if you have this issue, it takes 25 minutes to burn on the disc. (must change the book type to DVD ROM)
Old Dec 23, 2011 | 10:12 PM
Blooze's Avatar
Did you rip the ISO or acquire it? I already have the 2012 disk, but if disk scratching is a potential problem, being able to rip it and re-burn if my original was damaged would be nice.
Old Dec 23, 2011 | 10:18 PM
deantl's Avatar
I acquired it myself, I'm in Computer Forensics, so that helped.
Old Dec 24, 2011 | 01:59 PM
SharksBreath's Avatar
BANNED
hook me up with a disc! i'm trying to avoid sending mine in for as long as I can!
Old Dec 24, 2011 | 08:51 PM
Um...I want that disc. Merry X-mas to me! Seriously....that'd be amazing if you could help me out with that.
Old Dec 26, 2011 | 08:08 AM
mlody's Avatar
Few months ago i had a same problem but my disc wasnt as bad as yours. I went to a local electronic store and got myself a cd cleaning solution (the one with a little brush on disc) and ran it about 10-15 times and things started working fine for me - so far so good.
I know sending the unit to Alpine is cheap compared to a new unit or dealer replacement; however, i highly recommend $10-15 cleaning disc as the easiest and cheapest solution to try first.
Old Jan 1, 2012 | 01:19 AM
Fabo_07Type-S's Avatar
Yeah man, ive been having the same problem, anyway you can help me out with that disk? I would really appricate it.
Old Jan 4, 2012 | 05:38 PM
sung327's Avatar
8th Gear
hey, so i got the exact same message "DVD disc reading error, please consult your dealer" message, but ONLY when using the navi on freeways. on surface or side streets my navi works fine. i took it to the dealer and they did a "diagnostic" test (which they charged $150) and said i'd have to spend $3300 to replace the whole trunk unit.
i'm really curious if sending it in to alpine or using the cd cleaner works. please keep us up to date.
Old Jan 10, 2012 | 10:46 AM
paz5559's Avatar
2006 TL
Had the same issue, but was under warranty, so sent unit back through dealer. Parts werw back-ordered, so it took 6 weeks to get back.
Seem to remember that the audio from my GPS was preceded by a "ding", and came through the system speakers. Got it back, and now it comes from the center of the dash, without the ding. Am I remembering correctly? They had it for so long, I could well be mistaken.
If I am correct, how do i fix it?
Old Jan 10, 2012 | 01:37 PM
I hate cars's Avatar
Originally Posted by paz5559
2006 TL
Navi comes from the center, BT comes from the fronts.
Old Jan 10, 2012 | 07:52 PM
Fulani has a TL's Avatar
Care to explain how we do this??
Old Jan 19, 2012 | 03:45 PM
sung327's Avatar
8th Gear
Just a quick update: i sent in my navigation drive to alpine on wed 1/11/12 along with a check for $158. got it back yesterday wed 1/18/12....plus a NEW dvd disc! no more "disc reading error message" and navigation is working without a glitch! thank you alpine and acurazine!!!
Old Jan 19, 2012 | 04:14 PM
paperboy42190's Avatar
you guys know there is a tsb for the navigation drive scratching the discs. the previous owner of my car told me he brought the tsb to the dealership and they replaced the dvd drive for him for free.
Old Jan 19, 2012 | 04:21 PM
DAMN! That's quick. Faster return time I've heard of with this. Did they send you a new disc for your years TL..or the 2012 disc? I need to do this asap
I didn't buy mine at a dealership and haven't had any service done at a dealership...does this matter?? Also, what will I need if I went in there or can I just go in and say "hey...my nav drive's broken. Fix it!"
Old Jan 19, 2012 | 04:33 PM
sung327's Avatar
8th Gear
alpine sent me a new replacement disc for my 07 TLS. ver.4.92. which is what i had originally before it got scratched. it wasn't the new 2012 disc. sorry, i should have clarified that. also, from what i could find on other threads and postings, the tsb is only good for newer TL models...i believe 2009 and up (if my memory serves correctly). i have a 2007 and have more then 75K miles on it. so it wouldn't have applied to me anyways.
Good info, thanks
c1souk
Sep 28, 2015 11:20 AM
mars
Sep 28, 2015 11:03 AM
hpfiend
Sep 27, 2015 06:59 AM
Hines57
Sep 24, 2015 01:58 PM
