Unlocking Pin
Old Apr 10, 2008 | 10:48 AM
Icerrs's Avatar
Unlocking Pin
Hey guys, i bought a used 3g TL and the manual didn't come with the car. I want to use my bluetooth for my phone on my car but I need a PIN THAT I DON'T KNOW! Is there a way I can reset this or something, please respond back asap, I'm tired of hiding my phone from the cops on the highway lol.
Old Apr 10, 2008 | 11:08 AM
BlueTypeSGuy's Avatar
Are you talking about the PIN that's used for BlueTooth? If so, you make up the pin. If you created a pin like 1646, then your phone should enter the same thing to be paired.
Old Apr 10, 2008 | 11:17 AM
Will Y.'s Avatar
Registered but harmless
The 3G TL's manuals from through a link in the 3G Garage: https://techinfo.honda.com/rjanisis/...01_OMANUAL.asp
The PIN for the HFL is often 0123, 1234 or what is suggested in the manuals.
Old Jan 26, 2009 | 09:16 PM
GtMaxx's Avatar
N0w $hiftinG N/A
Yes i also need some assistance with resetting the wireless bluetooth i called up the dealer and they tole me it would be 125 to rest the pin number to link to the phone. thank you
Old Jan 26, 2009 | 10:12 PM
greco9885's Avatar
Bluetooth is a great thing. You can try disconnecting you battery for ~15 minutes.
Old Jan 26, 2009 | 11:07 PM
Thorin78's Avatar
Previous Owner
If you disconnect the battery, remember to have the navi and radio codes, if you have navi. Else, you're more SOL
Old Jan 27, 2009 | 02:43 AM
o4Komodo's Avatar
Rev High; Drive Happy
DISCLAIMER: PAIRING/SYNCING A PHONE WHILE DRIVING IS DANGEROUS AND MAY IMPAIR YOUR DRIVING.
PLEASE USE DISCRETION AND SYNC/PAIR OR ACCESS THE HFL MENUS ONLY WHEN THE VEHICLE IS FULLY STOPPED AND OUT OF TRAFFIC.
Push the talk button.
Say "CLEAR".
The system should prompt to clear all records in the system.
Say "Yes".
Wait a moment for the system to delete all previous entries.
Now begin pairing process.
This can be done by accessing the sub-menus then by saying "Pair" or "Pair A Phone".
It will prompt for a pin/password used to pair.
Say any 4digit number/code such as "ZERO ZERO ZERO ZERO" or "ZERO ONE TWO THREE FOUR".
The system will then search for all near-by phones.
Go into your phone's bluetooth menu. Within the bluetooth menu put it into "search mode" and look for "HANDS FREE LINK tm". Add this device to your phone.
Now input the 4digit number/code in the phone.
Pairing of the phone should be complete.
At some point in time, you will be prompted to give a name for your mobile device.
Once you have paired your phone, you may want to begin to create your phonebook so you do not have to say the phone number to the HFL or dial the person on your phone.
Now whenever your bluetooth is turned on, on your phone, it will automatically sync/pair with the HFL of the TL when you go in/out of the vehicle's connecting range.
Old Jan 27, 2009 | 02:54 AM
o4Komodo's Avatar
I hope that helps.
I may have left out some small steps.
Also keep in mind that sometimes when talking on the phone while the bluetooth is on before turning on and entering the car--the HFL may not connect/sync properly to your mobile device.
You are able to also talk on the HFL after the vehicle has been shut off--as long as the ignition is on the setting that runs the battery.
Old Jan 27, 2009 | 03:06 AM
InFaMouSLink's Avatar
Chapter Leader (NY/NJ)
you can also do a system reset. it'll erase all bluetooth devices HFL- SYSTEM- then follow instructions to reset
Old Jan 27, 2009 | 03:12 AM
o4Komodo's Avatar
I think that is the clear option---unless the system reset is another option.
The clear option deletes/wipes out all previous paired mobile bluetooth devices and phonebook entries.
Old Jan 27, 2009 | 06:48 AM
LoveMyTL-S's Avatar
For most mobile phones the default pin is 0000. Good luck.
Old Jan 28, 2009 | 10:30 AM
GtMaxx's Avatar
N0w $hiftinG N/A
Say "CLEAR".
Say "Yes".
ok but say if when you press and hold the talk button it says the system is locked "what is the 4 digit pass code" i dont think i can say clear and then if i unplug the battery then ?
Old Feb 10, 2009 | 05:08 PM
T-jay's Avatar
im baaaack!!
Im having the same problem, gonna go to the dealer cause i was told by the hfl customer service people that it should have been reset before i bought the car. I got a used 2005 RL.
copmagnet82
4G TL Problems & Fixes
Jun 29, 2016 08:09 AM
soupi
14
Nov 15, 2015 11:15 AM
SeaJay
Sep 30, 2015 09:15 AM
xsilverhawkx
Sep 28, 2015 06:51 PM
siularbar
1/2G MDX (2001-2013)
Sep 11, 2015 10:40 AM
