transfer a phonecall from HFL back to cellphone
Old Nov 28, 2005 | 09:14 AM
gainful's Avatar
just press the button and say "transfer"? Some times the HFL says "phone is in use" and refuses to transfer.
Whats the trick?
Old Nov 28, 2005 | 09:16 AM
A-Spec Guy's Avatar
B A N N E D
Good question....only way I have been able to get bluetooth to release in mid-call is to jam the earphone plug into the cell phone? This does raise a good question....I am sure there is a way to do it somebody can share>
Old Nov 28, 2005 | 09:46 AM
deandorsey's Avatar
this is going to be moved..lol
i believe it says this because it doesn’t recognize what you are saying, just say it again and it should work.
Old Nov 28, 2005 | 12:08 PM
HiTEC's Avatar
Does your phone support transfer with the HFL system. If you look on the Acura HFL site, not all phones support the transfer feature.
Old Nov 28, 2005 | 12:47 PM
bar2v's Avatar
Look Mean, Play Nice
I transfer from my car to my cell phone all the time. maybe its your cell phone. i have a moto e185 with verizon and have had no problems.
Old Nov 28, 2005 | 12:59 PM
crk1216's Avatar
I think the "Phone Is In Use" problem is a quirk in the HF software. I have the same problem with my v710 and have never found a good answer. Usually it only happens the first time your transfer a call until you shut the car off. The second and additional transfers will work fine.
It is some sort of issue with the initial recognition of the phone by the car. Needless to say I am sure it will be fixed in the future. BT is still in its infantancy so give it sometime...Like I said in my past posts about this issue.......I am sure the first headlights didn't work very well!
Old Nov 28, 2005 | 03:24 PM
jayelwin's Avatar
you sort of have to say "tronsfer" instead of transfer. I have that same problem - it just doesn't understand me. And I am a native english speaker.
Old Nov 28, 2005 | 03:56 PM
Actuary's Avatar
18,000mi. 29000km
I thought saying "transfer' to the HFL system transfers calls from Cell To Car. from Car To Cell, I go to phone's menu and disconnect bluetooth connection - Motorola V635
Old Nov 28, 2005 | 04:09 PM
rspoppel's Avatar
My cell phone (RAZR) has a setting the other way where I can have it "use handset" and it disconnects the bluetooth devices. have to do that when the headphones are not working 100%
Old Nov 28, 2005 | 04:22 PM
Riu's Avatar
Riu
2004 TL
the E815 has a switch audio option
Old Nov 29, 2005 | 01:04 PM
TallDarknFugly's Avatar
My cellphone has the option to switch. Just click on the "more" option and it gives u a list of options. You can thewn transfer to or from the phone and HFL.
Sony ericson s710
mada51589
Jan 9, 2025 04:40 PM
cobra10363
Jul 23, 2024 04:13 PM
Feb 25, 2020 09:57 AM
handsom-hustla
Nov 13, 2015 05:04 PM
