those using TvandNav2go convertor
Old Sep 13, 2005 | 10:38 PM
TurboSam's Avatar
Big Brother is Watching..
im kinda curious how you knew which wires were which. i have the pinout locations from the actual service manual from work, but my directions with the convertor doesnt use the same names for certain wires. anyone wanna help me out on what is what?
Old Sep 13, 2005 | 11:31 PM
TurboSam's Avatar
here is what the insturctions list
and here is what comes from the service manual
Old Sep 14, 2005 | 07:01 AM
rbf351's Avatar
Registered User
the pics you posted do not work
Old Sep 14, 2005 | 07:09 AM
TurboSam's Avatar
SERVICE MANUAL
http://www.imagestation.com/picture/...6.jpg.ORIG.JPG
ITEM INSTRUCTIONS
http://www.imagestation.com/picture/...0.jpg.ORIG.JPG
pics are huge
Old Sep 14, 2005 | 07:25 AM
TurboSam's Avatar
ok, try this again....
this is from the service manual
and this is what came as instructions
Old Sep 14, 2005 | 08:10 AM
gt1's Avatar
gt1
` . ' . SUV haterrr
First you cut R SIG, B SIG and G SIG from the manual. Connect the ends going toward the navi computer to Red in from source, 1 Green in from source 1 and Blue in from source 1 on your box. Connect the ends going to the screen to Red out, Green out and Blue out on the switchbox.
Old Sep 14, 2005 | 08:35 AM
TurboSam's Avatar
thanks for the info!!!!!
wow, i just realized the R sig etc. in the manual stands for RED...... wouldnt have had to ask this if it was stated in the directions
Old Sep 14, 2005 | 08:47 AM
TurboSam's Avatar
o. what about the "sync" signal? WTF is that?
Old Sep 14, 2005 | 09:28 AM
rbf351's Avatar
Registered User
sync should be the brown wire
Old Sep 14, 2005 | 10:27 AM
gt1's Avatar
gt1
` . ' . SUV haterrr
Id there is a problem with a sync, you will see a bunch of lines on your screen. Sometimes display is synced off the green signal, sometimes it is on a separate wire. "c" is a strange abbreviation for "sync", but nothing fits better. I suggest you start with RGB, and, only if you see lines on the screen, connect "c" wire the same way.
Old Sep 14, 2005 | 10:29 AM
dizzy1's Avatar
Not to steal your thread, but I have a question that maybe one of you could answer about this converter. I installed mine this weeekend and when I first turn on the car, the normal Acura wallpaper is blurred and hard to see for about 1-2 seconds while the converter powers up to let the bypass signal thru. After that, the screen looks and works like normal. Is this normal or are you guys hooking the power to a constant 12+ so there is no start up delay.(this would drain the battery?) Or are you hooking up something differently to make this not happen. Thanks
Old Sep 14, 2005 | 10:45 AM
TurboSam's Avatar
but what wire is it on my vehicle harness?
Old Sep 14, 2005 | 11:00 AM
rbf351's Avatar
Registered User
wire 12 which is colored brown, and called C sig
Old Sep 14, 2005 | 11:01 AM
rbf351's Avatar
Registered User
you must be hooked into a wire that does give either the proper voltage or doesn't turn on for whatever reason till the navi boots up.
i have mine hooked into the cig lighter wire, which is a switched 12V wire
Old Sep 15, 2005 | 08:26 AM
dizzy1's Avatar
Fixed it, turns out the noise filter that is wired with the dvd player must have an internal relay and is delayed about 2 seconds. I hooked it befored the filter and everything starts up like it used to. Thanks for all the help.
buste2
Aug 17, 2006 08:32 PM
typeR
Nov 28, 2001 05:00 AM
syncivic
Oct 31, 2001 03:40 AM
AKRY
Aug 28, 2001 09:09 PM
AKRY
Aug 26, 2001 10:47 PM
