Those with a PS2 in the glovebox... help
Old Apr 29, 2007 | 10:55 PM
Kennedy's Avatar
OMGWTF4THGENTL
Quick question for you guys that hvae PS2's in the glovebox...
I'm finishing up my PS2 install, but I'm having a slight problem. I found today that the video/power connection on the back the unit are kind of "in the way", and making the unit stand up a bit too far, which in turn make the glove box door difficult to close.
Did you guys dremel a big hole in the bottom of your glove box for these cables to go through? How did you adress this clearance issue? No way my glovebox will close with this clearance issue.
Thanks.
Old May 1, 2007 | 01:21 AM
Kennedy's Avatar
OMGWTF4THGENTL
NE1 out there?
Old May 1, 2007 | 01:41 AM
datmrman's Avatar
Are you using the full size or slim PS2. The last PS2 install thread I've seen was a while back ago and I think they dremeled a hole in the glove box. I remember because the guy then changed his mind I was trying to find a replacement.
If you don't want to deal with that, there is always the bottom of the passenger seat.
Old May 1, 2007 | 02:08 AM
MoHaWk2003's Avatar
TCU Frogs!
my ps2 slim is in the glove box, but i didn't cut anything. it barely squeezes by when i close it
Old May 1, 2007 | 08:35 AM
Kennedy's Avatar
OMGWTF4THGENTL
It's the slim version.
I wish I could get someone to confirm this. I PM'd ITL with no response.
Old May 2, 2007 | 06:44 PM
kataklyzm's Avatar
i dremeled a small hole in the back of the glovebox.. works out better since i'm using the 2.4ghz wireless controller. still fits fine. i used a slim ps2 btw
Old May 2, 2007 | 08:18 PM
Kennedy's Avatar
OMGWTF4THGENTL
back or bottom? do the plug wires stick out the hole? That's the only way I can see how this thing will sit flat.
Old May 2, 2007 | 11:48 PM
kataklyzm's Avatar
in the back.. both of the plug ends stick out of the hole, so the back of the PS2 is flush with the back of the glovebox
Old May 5, 2007 | 06:17 PM
MoHaWk2003's Avatar
TCU Frogs!
acuradan69
Apr 25, 2003 04:57 AM
kchen_RENAMED
May 10, 2002 02:36 AM
jacobzking
May 7, 2002 01:38 PM
Hoffhines
Mar 21, 2002 03:34 PM
