Is There A V600 Fix?
Old Oct 8, 2004 | 08:59 PM
Nitrotiger's Avatar
Ok guys is there a flex version that is going to work with the TL i think this phone is going by by if i can not fix this thinng. Motorola is coming out with new phones so hopefully they fixed the current issues. So i guess the question is has any 1 fixed there v600 to work with the tl. i have looked at all the forums and it seems there are problems which i do not want.
Old Oct 9, 2004 | 12:01 PM
nortynorty's Avatar
Are you using TRIPLETS_G_0B.09.4AR as your firmware? Mine seems to be working better once I flashed to that.
Old Oct 9, 2004 | 06:22 PM
2004Tru3Lov3's Avatar
S/W Version on my V600 is TRIPLETS_G_08.09.45R and it's also working great with my HFL.
Old Oct 9, 2004 | 11:38 PM
Nitrotiger's Avatar
no im not were did you get it please send me a link to get it.
Old Oct 10, 2004 | 05:51 AM
nortynorty's Avatar
nitro, go to http://v600.cjb.net/
Old Oct 10, 2004 | 10:39 AM
PAR5zN2's Avatar
Originally Posted by nortynorty
This site is in Spanish. Is there an English site?
Old Oct 10, 2004 | 05:09 PM
cullal's Avatar
I have been using version 45R with my V600 for the last 6 months and it works great with the HFL. Only he battery indicator does not show on the MID. Goto http://v600.cjb.net/ its in english...
Old Oct 10, 2004 | 08:52 PM
Nitrotiger's Avatar
I went there but could not fine the version you were talking about please help thank you
Old Oct 11, 2004 | 05:55 AM
pinito's Avatar
Mine works fine out of the box - no upgrade.
Old Oct 11, 2004 | 07:55 AM
nortynorty's Avatar
Don't know why this is coming up in Spanish, it is an English site. The following is a copy/paste of what you see when the link is followed. There is also a lot of information in the Motorola section of www.howardforums.com about flash and flex.
Welcome to my Motorola V-Series Site
Laser Eye
To flash, you need a USB cable and PST software/patch from www.motclub.com
My Current Setup:
Hardware: V600
FW: TRIPLETS_G_0B.09.4AR
Flex: SE6446AXXF1148
Language Pack: 0003
Of course, SEEM-edited all to hell.
xlr8's AWESOME SEEM-editing site
To acheive this, flash the 9.38 fw/flex/LP file, then the 9.23 FW.LP, then the 9.4AR FW file.
Firmware Files
TRIPLETS_G_0B.09.4AR_reflash
This file contains a stable, bug-free firmware(newest) for your VXXX phone.
TRIPLETS_G_0B.09.38R
TRIPLETS_G_0B.09.38R FW with SE6446AXXF1148 Flex and Language Pack 0039. Very fast, very stable, flex and fw combonation.
TRIPLETS_G_0B.09.23R
This is motclub's beta fw. This fw is very unstable, but it is the only place to include 0003 Language pack(my favorite). I would flash this, and then the newest standalone flash(will not overwrite LP) to get the ideal LP for Americans, North and South, as well as the ideal FW version.
Flex Files
GI9V600000AA0E9 Flex File
This flex may be applied on top of the firmwares shown above. It adds AIM and adds some engineering mode features. I have found this flex to be very stable, but has greatly reduced my idle battery life.
English V600 Manuals
V600 English Manual
HS810 Bluetooth Headset Manual
Please do not contact me for support, use HoFo for questions/problems.
Contact me if you have something to add, or if one of my links are broken:
PM to jtopping on:
Old Oct 11, 2004 | 11:20 AM
cblackburn's Avatar
Can't you just swing by the ATT store (or whatever) and have them upgrade your firmware/flex/etc?
Old Oct 11, 2004 | 02:47 PM
Nitrotiger's Avatar
nope they have to send it out
Old Oct 20, 2004 | 03:28 PM
Not sure what to do?
Just a little help. I read this thread, but I really don't understand what I have to do here. I just got an '04TL and a Motorola v600 phone with Cingular service. What do I need to do to make this phone and bluetooth work best for me ? Any guidance would be greatly appreciated. Thanks!!
Old Oct 20, 2004 | 09:59 PM
Nitrotiger's Avatar
its already bluetooth you have to pair it up with the car and you will be all set. just follow the manual.
Old Oct 21, 2004 | 01:16 PM
cyargeau's Avatar
caller id?
Hi,
I also have the V600 and I do not get the incoming call caller id show up, is this normal?? I thought the display would show who is calling as well, thanks.
Old Oct 21, 2004 | 03:39 PM
pinito's Avatar
mine does.
Old Oct 24, 2004 | 08:44 AM
Still having a big problem with my v600. Got it paired, and can make out going calls sometimes, when the voice recog gets it right, but I can't answer an incoming call? HELP!
Old Oct 24, 2004 | 11:56 AM
cyargeau's Avatar
software version
Hi,
Is it possible that people can post which software version they are using? Mine is working great except for the no caller id on incoming calls??? I am using triplets version 94. Others?
Old Oct 24, 2004 | 01:22 PM
How do I find out what version I am using??
Old Oct 24, 2004 | 01:29 PM
cyargeau's Avatar
setp
Go into main menu, setup, phone status, other information and then S/W version it will tell you there.
Old Oct 24, 2004 | 01:41 PM
OK, thanks! I have TRIPLETS_G_0B.09.2FR
What do I need to do to get this v600 to work correctly? I have CINGULAR as my provider.
Old Oct 24, 2004 | 02:17 PM
cyargeau's Avatar
more info
If you do a search for V600 and read thru the threads you will find all sorts of info. Basically you need to get a usb Motorola cable and reflash the software in the phone. It doesn't take long but you do need to read a bit to get the right info. I did mine and it went smooth after reading. Software for latest triplets that I used is here http://v600.cjb.net/ this site is mentioned in lots of other threads here as well.
Old Oct 25, 2004 | 07:56 AM
nortynorty's Avatar
JMan, cyargeau is correct. I too have Cingular and am using TRIPLETS_G_0B.09.4AR. Works well.
Old Oct 25, 2004 | 02:17 PM
mobilezen's Avatar
To Everyone
Keep in mind if you do any kind of firmware upgrade on your phone that it can ultimately void your warranty. If anything does happen to the phone after you have flashed it, your mobile provider may deny you any kind of warranty for tampering with the system's files. So if you decide to upgrade, do this at your own risk.
These are the firmware/flex versions I have:
GI9V600000AA0E9
It's been awhile since I have updated my firmware collection but that is what I have so far. If anyone has something newer, please chime in.
Mike734
Dec 10, 2021 01:25 PM
SidhuSaaB
May 30, 2020 12:40 AM
thegipper
Sep 28, 2015 01:01 PM
h22lude
Sep 27, 2015 06:22 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
