System lock - big problem :(
Hi !
I bought my Acura TL 2004 year ago - after one year without problems - I ship this car to my country ( poland ) and I dont know why and I start playing with voice commands - after that I activate pin code to system ( all commands ar locked now ) and because car was used i dont know what is pin code - dealer dont know this too - and in poland we dont have acura dealers so what to do ? dont say that I need to go with this car to usa
Mods-can you verify his IP address is from Poland before I respond to his post?
Could've been someone with a hot navi/radio trying to get the codes.
OP, since you left the U.S., you may be out of luck. Any Acura dealer (and maybe a Honda dealer) can give you your codes based on the serial number of the navi and radio unit (each has a PIN code). However, I don't think you'll be able to convince a dealer to do this over the internet or telephone. Usually they want to see the car in person.
Give it a try. Maybe a photo of the car registration with your name on it and a copy of your driver's license plus of photo of the navi screen displaying the serial # would be enough to convince someone.
The navi serial number is on the underside of the navi unit in the trunk. You can also pull up the number on the screen by entering the navi diagnostic screen: press and hold the Menu, Map/Guide, and Cancel buttons for about 5 seconds.
Select the Unit Check screen, then Navi ECU. The serial # will be on that page.
Hope this helps and good luck!
I missed that you had your car in the U.S. for a year before shipping it. Did you happen to develop a relationship with a local Acura dealer before leaving? Did you buy it from an Acura dealer? If so, I would start there since they know you.
Yes right now I'm in poland - of course I can send everything ( pictures of my car but for what ? I dont understand ) I dont have NAVI my acura is with normal radio and I have pin for this - I'm talking about system so when I vant to use voice commands ( or pair phone or everything what is in menu in small screeon in gauges - first I need to say pin number - and probably first owner set it and now I can not do nothing - so I hope I tell ypu more about my problem - honda dealer in poland dont have any software for acura so its not so easy go to honda because they can not do nothing.
Lucas
Lucas
Off roading in his
I found this through searching https://acurazine.com/forums/3g-tl-audio-bluetooth-electronics-navigation-94/help-dead-hfl-694680/ see if it helps
rockyboy
12-06-2022 02:29 PM
mada51589
05-03-2022 08:54 PM
cycdaniel
12-17-2019 10:58 AM
tman570
06-11-2019 07:56 AM
