Switchback turn signal?
Old May 13, 2008 | 04:55 PM
EcKoHeD72's Avatar
Scuba_Steve
Hey guys, I have an '07 TLS and just got my switchback turn signals in. My only question is which resistors I need for them? Also, where and how to install them. Thanks for any help u can provide!
Old May 13, 2008 | 10:54 PM
Fulani has a TL's Avatar
Search is your friend on this site
DIY I made
https://acurazine.com/forums/showthread.php?t=178762
Old May 14, 2008 | 02:52 AM
EcKoHeD72's Avatar
Scuba_Steve
Thanks bro! So its pretty much the same for the fronts right?
Old May 14, 2008 | 07:35 PM
omnuts's Avatar
2006 TL: WDP/Ebony
You only need to instal in the rear on each side (1 resistor per side), or front.. BUT only one end.. it's easier to instal in the rear, but some have done it in the front..hope this help GL
Old May 21, 2008 | 03:09 PM
EcKoHeD72's Avatar
Scuba_Steve
So, I can install the resistors in the rear for the FRONT turn signals? Sorry, I've never done this b4... As u can tell!
Old May 21, 2008 | 05:34 PM
omnuts's Avatar
2006 TL: WDP/Ebony
yes instal in the rear easier and ,more access
Old May 21, 2008 | 07:14 PM
EcKoHeD72's Avatar
Scuba_Steve
Thanks bro! Just ordered the resistors. I'll let ya know if I have any more problems when it comes time to install!
Old May 22, 2008 | 05:10 PM
izmyttz's Avatar
which ones did you buy? i got these..they are tiny..worked great..i installed them to the frame behind or above the headlights when i had them out.
CLICK HERE
Old May 22, 2008 | 06:34 PM
omnuts's Avatar
2006 TL: WDP/Ebony
^ those will work fine...
Old May 22, 2008 | 08:32 PM
EcKoHeD72's Avatar
Scuba_Steve
I went with the same ones that Fulani recommended... They're 4 Ohm 100W Non-Inductive Dummy Load Resistors, I know they're overkill, but overkill never hurt anyone, when it comes to resistors! Besides, they're only a few bucks more...
Old May 23, 2008 | 05:53 PM
Porkipine's Avatar
'07 NBP TL
since u installed the front blinkers and the resistor, does that mean u need to switch the back bulbs to leds too? orelse won't it blink slower?
Old Jun 30, 2008 | 04:04 PM
EcKoHeD72's Avatar
Scuba_Steve
Installs done, took a while for me to get time to do it... Went very smooth. The only difference that I did, was instead of using t-taps, I soldered. I know that when using t-taps u can often have problems later on down the line. Easy, inexpensive, and definitley worth it!
Nope, the resistors don't slow down the OEM bulb, just LEDs.
pplcrew
Jan 30, 2021 08:59 AM
SidhuSaaB
May 30, 2020 12:40 AM
Ty-Sama
Sep 21, 2015 05:45 AM
Greengecko
Sep 16, 2015 08:19 PM
