Suggestion on a dead console
Old 12-28-2008, 04:21 PM
9th Gear
bmchan's Avatar
I have a 2004 TL without the navigation. I just had the CD player replaced two months ago under warranty. Today I can't turn the radio console on at all. No power. The bluetooth icon appears on the screen and the blue lights around the knobs are on but no power - no CD no tape player.
I have an iPod cassette adapter in the tape player and as I vacuumed the car today I sucked the plug into the rubber hose. I can't imagine a static charge would kill the entire system. The fuse (#5) appears ok.
Any suggestions would be appreciated.
Old 12-28-2008, 07:18 PM
csmeance's Avatar
Received 2,016 Likes on 1,435 Posts
something internally may be damaged. Acura should warranty the repair for 12 months or 12K.
Old 12-29-2008, 07:21 PM
9th Gear
bmchan's Avatar
Thanks. My warranty ran out in November. Would you recommend going to the dealer or an auto audio shop?
Old 12-29-2008, 07:55 PM
csmeance's Avatar
Your best bet would be to try taking out the radio and checking the internal fuse inside it.
Old 01-09-2009, 06:26 AM
9th Gear
bmchan's Avatar
For the record - Acura tells me there are three fuses that impact the radio (and not internal to the radio). I'll post here when I get it fixed.
Old 01-09-2009, 08:52 AM
PeterUbers's Avatar
You've checked all the fuses -- you can remove the negative terminal off the battery for 10 minutes (have your radio code ready) and then re -seat the neg terminal...
If they replaced the headunit only 2 months ago -- i agree with the above post where they should warrant their replacement unit for at least 6 months...
Old 03-08-2009, 11:11 AM
9th Gear
bmchan's Avatar
Bump.
The outcome was that the dealer replaced it free under the warranty, after checking all the fuses in the shop. They found one out but that did not help. They hinted that I could be liable for $300 if they found it was something I did (ie the iPod cassette adapter).
I am no longer going to use the cassette adapter for my iPod.
Old 03-08-2009, 10:04 PM
PeterUbers's Avatar
LOL! You could be "liable"???
What are they gunna do, have an Acura detective call you in a couple weeks and charge you the money? Is there a head-unit autopsy? I hope you wiped your prints...
Glad they took care of it.
Old 06-21-2009, 07:52 PM
9th Gear
bmchan's Avatar
Bump.
To close the loop on this thread, they replaced the unit (no charge) and I no longer use the iPod cassette. All is well.
SidhuSaaB
05-30-2020 12:40 AM
knight rider
03-04-2016 08:59 AM
InFaMouSLink
10-27-2015 06:52 PM
kb1rl
09-30-2015 10:17 AM
hashbrown
09-29-2015 12:13 PM
Quick Reply: Suggestion on a dead console
