Sub stopped punchin', any ideas???
Old May 23, 2011 | 06:27 PM
ericksTL's Avatar
Driving to work this morning my subs stopped hitting , I drive an 07 TLS .... I'm running a 500/1 jl amp and a kicker l7... my remote wire is ran to the fuse box in The kick panel on the drivers side via an add a fuse , still has power..... the main fuse by the car battery isn't popped and the amp still shows power.... I checked the hi /low converter that is located to the factory sub wires wit a brand new hi/low converter and still nothing.... the only thing I can think of is the sub is blown witch I highly dought or the fuse for the factory amp is blown witch I have no idea where its at... any ideas? Where's the fuse located for said amp?
Old May 23, 2011 | 08:59 PM
mau108's Avatar
Pull the sub out and see if the wires that go to the cone have been damaged.
Old May 23, 2011 | 09:15 PM
greddycl-s01's Avatar
does the amp have a protection mode...if it does disconnect the car battery and reconnect to reset everything
Old May 23, 2011 | 09:35 PM
rockstar143's Avatar
Yeah, if you got juice at the amp...turn gain WAY down and connect ANY speaker you have laying around (even the factory one), then you'll know if it's the speaker or the amp. Probably one of the wires inside the box came loose from the speaker.
Old May 23, 2011 | 09:59 PM
ericksTL's Avatar
You guys are awesome .... Yup the wire got disconnected from the sub this I guess I was just bassin too hard this morning lol, thanks guys for the assist !!!
Old May 23, 2011 | 11:38 PM
no problem
Old May 24, 2011 | 09:27 AM
RJANACONDA's Avatar
Registered TL Lover
yeah that happend to me a couple of times. its always scary.
another time the it died out while sitting in traffic in 105 degree weather with just windows down (probably was 110+ in trunk) started working after i turned music off open ski hole and blasted ac for a while
Old May 24, 2011 | 11:36 PM
Illmo's Avatar
been there done that...Thats one of those easy fixes, that people often over look.
SidhuSaaB
May 30, 2020 12:40 AM
spoiler900
Oct 10, 2015 06:48 PM
kixo
Sep 25, 2015 03:07 PM
2ManyHobbies
Sep 24, 2015 09:23 PM
