sub amp won't play while set to the...
Old Jun 8, 2011 | 10:10 PM
MistaWet's Avatar
accessory position. When washing my car, I like to play music but my recently bought 3G TL will only play my after market sub when the key is set to the "on" position. If I have the key set to the "accessory" position it will play everything except for the sub.
I didn't install this system but I can tell you the power cable is connected directly to the battery. Not sure I've seen this kind of hookup before.
Anyway, if anyone knows why this is happening I'd greatly appreciate some feedback.
Tks
Old Jun 8, 2011 | 10:17 PM
djtsmith007's Avatar
ElectroMechanicalEngineer
Tks
That power cable is for the amp, the remote turn on wire for the amp must be wired to a wrong spot.
Old Jun 8, 2011 | 10:38 PM
csmeance's Avatar
First of all, it isn't a good idea to play a system off a battery (even the stock one) at all! It discharges the battery and can either leave your car in a non-starting condition and as well will reduce the life of your battery.
As far as the problem, check the remote turn on wire for your amplifier. More than likely it's hooked up to an ignition only source vs. the remote turn on for your other amplifier.
Old Jun 9, 2011 | 10:10 AM
MistaWet's Avatar
Thanks guys for the responses. Remote turn on wire for the amp is connected in the wrong place. Will check that tomorrow.
Thanks for the prompt responses.
Feb 25, 2020 09:57 AM
Soul_Deamon
4G TL Problems & Fixes
Nov 2, 2015 04:32 PM
Pegon95
Sep 15, 2015 01:54 PM
braveheart
Sep 7, 2015 08:12 AM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
