Stock sub wires to line out converter?
Old Feb 24, 2014 | 05:08 PM
STL TL's Avatar
I have been searching around but I get so many mixed options. I am wanting to know if I can use the stock sub wires and hook them into a loc? Would I be able to use this and control the sub from the radio just like the stock woofer?
Old Feb 24, 2014 | 05:15 PM
Old Feb 24, 2014 | 05:34 PM
STL TL's Avatar
Since the loc has left and right channel how do I wire it up assuming the sub just has two wires going into it.
Old Feb 24, 2014 | 06:50 PM
MekoTL's Avatar
There are many threads that both talk about and show pictures on how to do this. There's a full DiY too I believe.
Anyway, you would just unplug the exiting sub and wire in the LoC into the wires directly. From there, you RCA to the amp. You don't wire your sub to the LoC.
If your amp has SLIs then you don't even need the LoC.
Old Feb 25, 2014 | 08:36 AM
350's Avatar
350
My first ricer
You may not need a LOC if your amp has high level inputs, my Alpine works without it. If it's a mono amp it doesn't matter if you do left/right or wire it to both. I just cut the stock connector from the sub, extended the wires a bit, and right to the amp. The stock radio controls it fine.
Old Feb 25, 2014 | 06:42 PM
pearl905's Avatar
You Don't have cut your stock sub connector, u can also splice it so u can run both subs at the same time if u like
cycdaniel
Dec 17, 2019 10:58 AM
Soul_Deamon
Nov 13, 2018 04:44 PM
IIDXholic
Oct 8, 2015 07:53 AM
JarrettLauderdale
2G CL Dynograph Gallery
Sep 21, 2015 07:51 PM
alan_rich
Sep 7, 2015 11:08 PM
