Stock Sub?
Old May 31, 2010 | 05:05 PM
A-Spec-CaliBoi's Avatar
Stock Sub?
anyone Know Why Our Stock Sub Sounds Like Crap and Is Their Anything That We Can Do About It? Can We Do Anything to make It Sound Better?
Old May 31, 2010 | 05:08 PM
princelybug's Avatar
LIST/RAMEN/WING MAHSTA 짱
Why it sounds bad? It's stock.
If you hook up an aftermaket amp to it, you'll improve the sound. Otherwise, the only other option is to get an aftermarket sub in the trunk.
Old May 31, 2010 | 05:14 PM
ok just so i know im not crazy, when you play certain songs on it does it sound like its blown? I always thought maybe it was just rattleing very loud but idk. And i didnt know we could hook up and aftermarket amp to it. if i do wat wattage should i have hooked up to it.
Old May 31, 2010 | 05:19 PM
How old is your car? How loud do you play your music? What setting do you have your "Bass" at? All of these will play a part in how fast your stock sub will blow. Sounds like it already has.
Here is a fix for the rear deck rattle: http://www.in.honda.com/Rjanisis/pubs/SB/b04-043.PDF
Maybe someone else will chime in with the wattage of the OEM sub to help you out, as I don't know it off the top of my head.
Old May 31, 2010 | 05:22 PM
Here's what another member did to solve the stock sub issue: https://acurazine.com/forums/showthr...ker+size+specs
Old May 31, 2010 | 05:24 PM
Our subwoofer:
Subwoofer
Impedance: 2 ohms
Rating: 40W
hashbrown
Feb 18, 2022 11:20 AM
Jul 16, 2017 07:33 AM
vpasla1
Sep 17, 2016 07:24 PM
DerrickW
Nov 15, 2015 05:52 PM
rangomango
California
Sep 24, 2015 05:47 PM
