Stock Audio Specs?
Stock Audio Specs?
I've read several threads on replacing speakers and amps. I've learned about ANC and subwoofer feedback, etc...
What I haven't found is the specs on the stock system (07 Type S (nav 5.1):
1) What is the impedance & wattage on the stock sub amp?
2) What is the impedance & wattage on the stock amp driving the door speakers?
3) Are there step-by-step instructions for removing the rear deck?
I'm considering a DYI sub upgrade.
Regards,
Texas TL
Regards,
Texas TL
Stock Amps in 07 TL Type-S ?
Ping... Anyone out there with access to this info?
Regards,
Texas TL
Regards,
Texas TL
Stock Sub is at 2 Ohms 40Watts
The front door speakers are at 2 Ohms... because they are bridged with the tweeters... 10 Watts on the tweeters and 20 Wats on the doors....
The rears are at 4 Ohms - 20 wats each...
The Center speaker is at 4 Ohms - 15 watts...
This is all by memory ... I could be off +/- 5 Watts on each...
the Rear Deck Removal...
1. Remove rear bottom cushion
2. Remove rear seat back
3. Remove C-Pilar Panels
4. Remove Rear Deck
https://acurazine.com/forums/showthr...ar+remove+deck
I do it in less than 10 minutes... but you might take 30 minutes... since it's your first time... all the information is on this forum...
Search and you shall get more in depth information...
4. Remove Rear Deck
Please look at the Sticky thread on this Forum " 3G TL Audio & Electronics FAQ" posted by datmrman... Alot of information there...
here is a link to the Stock Amplifier Specs...
https://acurazine.com/forums/3g-tl-audio-bluetooth-electronics-navigation-94/details-stock-tl-amp-558485/
Here are the scans for removing the rear deck....have fun!
https://acurazine.com/forums/3g-tl-tires-wheels-suspension-97/how-remove-back-seats-put-suspension-3g-garage-f-070-a-567460/
akbears15
15
Nov 5, 2015 07:06 AM
sockr1
Oct 1, 2015 01:31 AM
DiamondJoeQuimby
Sep 10, 2015 11:40 AM
