whats so special about those image dynamics? i got the jl sub 8w3v3 with jls small vented box for it but i love jbl stuff, will def check it out for upgrade when i get the cash!!! but now im thinkin 2ohm componants cause the alpine mrx-v60 pushes more using 2ohm
Quote:
The ID's are known for really good mid-bass for their price range.Originally Posted by jdaddyac
Quote:
Quad jbl gto 8's should be <250 and work in <1.5 cubes
GTO804 from jbl is only 79.95 free ship from jblOriginally Posted by eggyhustles
What's your budget for a sub stage?Quad jbl gto 8's should be <250 and work in <1.5 cubes
Quote:
eh, i was wrong.Originally Posted by eggyhustles
there's a couple on ebay for 50-55ish
58 each
http://cgi.ebay.com/JBL-GTO804-CAR-A...ht_2564wt_1139
235 for 4 of them. Free shipping.
Use this for power
http://www.sonicelectronix.com/item_...-7508-R-B.html
4 sundown sa 8's or even 4 alpine type r 8's would've been awesome. Cost some coin, though.
yea i been lookin at that alpine NEW ALPINE TYPE-R 8" 1000W , also what does anyone know about this amp and components(brand powerbass) http://www.sonicelectronix.com/item_...AX-5640FD.html and PowerBass L-60CXPowerBass L-60CX ??
4 of those with 200-250w each would sound awesome.
Powerbass makes decent entry level amps. never heard their mids, though.
Coolest A-zine Member
How did we go to replace factory sub to 4 8's? lol. That's a big jump..
What's the plan here??
Let's throw another wrench in...
SSA just released the 15" dcon for 139
Fs 33.5hz
Re 7.8
Qms 4.88
Qes .49
Qts .44
Mms 144g
Xmax 16mm
Vas 142.2
Sd 810 cm^2
BL 22.1
SPL 92.2 1W/1m
Wattage: 300wRMS
Sealed: 2.0-3.0ft^3
Sealed Optimal: 3.25-4.0ft^3
Standard Ported: 3.0-4.0ft^3 @ 28-33hz
Optimal Ported:4.0-5.0ft^3 @ 28-33hz
92 db @ 1 w efficiency. These will get LOUD and sound pretty damn good with minimal power.
http://www.soundsolutionsaudio.com/s...7B47%7DS4.html
Fs 33.5hz
Re 7.8
Qms 4.88
Qes .49
Qts .44
Mms 144g
Xmax 16mm
Vas 142.2
Sd 810 cm^2
BL 22.1
SPL 92.2 1W/1m
Wattage: 300wRMS
Sealed: 2.0-3.0ft^3
Saw this over on DIYMA
http://www.amazon.com/Morel-Maximo-i...1005287&sr=8-2
TL owner
ive heard the 8" Type r in the alpine demo camaro and those things are nice. The Alpine imprint is a nice unit for the price. ive used them on a few cars ive done and was surprised with the end result, there by no means on the Level of a BitOne but in its same respect a great OEM integration device.
I hate cars
close
- Join DateMar 2006
- LocationBakersfield
iTrader Positive Feedback0
iTrader Feedback Score(0)
Liked:1,818 Times in 1,287 Posts
Fs 33.5hz
Re 7.8
Qms 4.88
Qes .49
Qts .44
Mms 144g
Xmax 16mm
Vas 142.2
Sd 810 cm^2
BL 22.1
SPL 92.2 1W/1m
Wattage: 300wRMS
Sealed: 2.0-3.0ft^3
I like. Originally Posted by eggyhustles
Let's throw another wrench in...SSA just released the 15" dcon for 139
Fs 33.5hz
Re 7.8
Qms 4.88
Qes .49
Qts .44
Mms 144g
Xmax 16mm
Vas 142.2
Sd 810 cm^2
BL 22.1
SPL 92.2 1W/1m
Wattage: 300wRMS
Sealed: 2.0-3.0ft^3
Should sound better and get far louder at less power than any 8" mentioned. Why send that 8" 1,000w when you can send this super efficient 15" 300 watts and get more output.
Quote:
Join the club. Found a buyer for my 12w6's and PDX1.1000 for $700...think I might do it and do the SBP15'sOriginally Posted by geekybiker
Makes me want to build an IB setup.
Quote:
The video on the spec page says "free air" That's car audio speak for IB, right?Originally Posted by eggyhustles
IHC, looking over the t/s of the dcon, You think it'll work IB?
Quote:
Nah, 2 completely different things. In IB, the sub(s) use the trunk itself as an enclosure.Originally Posted by geekybiker
I hate cars
close
- Join DateMar 2006
Quote:
It looks like it will work great. .44qts, a low 144g mms, and high efficiency, it should sound great with especially quick transients. Xmax is 16mm, but do you know the total mechanical excursion limit? The lower qts is especially good if you're using two of them.Originally Posted by eggyhustles
Sounds like you'd need 3-4 to get any SPL out of them at all at those levels and with that xmax right?
OP- I'd go with a 10" in a small sealed box on the side(s) of our trunk. Search the first few pages and you'll see them and where to buy them. VERY trunk space friendly and will sound 10x better than a small 8" in the rear deck
I hate cars
close
- Join DateMar 2006
2 would probably be fine. Two 15s barely have to move to produce decent SPL. I have no idea what the total excursion is but I would guess 20mm or more.Originally Posted by Trunk Monkey
Sounds like you'd need 3-4 to get any SPL out of them at all at those levels and with that xmax right? OP- I'd go with a 10" in a small sealed box on the side(s) of our trunk. Search the first few pages and you'll see them and where to buy them. VERY trunk space friendly and will sound 10x better than a small 8" in the rear deck
I have a feeling we're going to see a new thread from the OP in a few weeks about replacing the 8" with a larger sub.
16mm of xmax and that much efficiency should lead to some decent spl. Originally Posted by Trunk Monkey
Quote:
I gotta ask about thatOriginally Posted by I hate cars
I hate cars
close
- Join DateMar 2006
Quote:
With that much motor strength, it should get very loud in a ported enclosure.Originally Posted by eggyhustles
im using this jl in the small enclosure that jl sells together.
JL AUDIO 8W3V3-4 500W 8" CAR SUB WOOFER ENCLOSURE BOX
i want to save as much space as i can
I hate cars
close
- Join DateMar 2006
I'm not sure why you asked for advice, you did exactly what you wanted despite other recommendations. You could've done a single 15" for less money and saved more trunk space than the 8" in a box.Originally Posted by jdaddyac
im using this jl in the small enclosure that jl sells together. JL AUDIO 8W3V3-4 500W 8" CAR SUB WOOFER ENCLOSURE BOX
You could've done a 10 or 12" in one of the corner boxes and saved space.
I honestly hope you're satisfied with your new setup but output is not going to be that great.
Wow! $234 for an 8" w3 in a crappy box...ouch. I picked up 2 12" w6's in a box for $150 more!!
I have a feeling we'll be seeing him shortly...
Hell, I got a 10" in a box for like $80. Got to love parts express.Originally Posted by Trunk Monkey
Wow! $234 for an 8" w3 in a crappy box...ouch. I picked up 2 12" w6's in a box for $150 more!!I have a feeling we'll be seeing him shortly...
i jus wanted opinions, u guys are far more into the loud stuff then i am these days,i left the car audio scence about 7 years ago so gimmi a break here, lol i know u guys know ur stuff, thats why i asked, just to get an idea, i dont want all those 10" and 12" i wanna save as much space as i can cause i didnt even want to get a box but too much hassle riggin the back dash enclosing and whatever mods to do that, thats just the smallest one i could find. what do u mean corner boxes? a 10" in a corner box would save more space then that jl enclosure? where is this? and slow down guys, have u ever heard this 8" jl in this small enclosure? if not then u never know,but ok ok ok, if there is such a thing as a 10" or 12" smaller im sure i will upgrade lol
Thats why i said go IB
You'll retain 99.9% of your trunk space. If you wanna save even more space, get tiny amps you can install under the seats.
IB (infinite baffle):
- Hardly any space taken up and you can use 2 15's if you wanted.
- Small power requirements
- Easy install
- Cheap
Sealed Box in Corner of Trunk:
- Less space than IB.
- Still plenty of output for most users
- Found Here: http://wickedcas.com/product.php?pro...&cat=12&page=1 and http://www.audiointegrations.net/cat...75/8253904.htm. Or like this: https://acurazine.com/forums/3g-tl-audio-bluetooth-electronics-navigation-94/new-custom-sub-enclosure-pics-824695/
All > 8"w3. Though these are more expensive, it'll actually be cheaper instead of redoing the system....see you in 2 months!
- Easy install
- Cheap
- Found Here: http://wickedcas.com/product.php?pro...&cat=12&page=1 and http://www.audiointegrations.net/cat...75/8253904.htm. Or like this: https://acurazine.com/forums/showthread.php?t=824695
ok now that is more like it, that is really cool, lil out of my price range at the moment, but def gonna do a 10" driver side Wicked Cas down the road. i just cant handle it too loud these days cause of health reasons. see i know u guys know where all the good stuff is, i truly appreciate ur input, trust me even though i dont get exactly what u say,it helps me decide for what i want and need. thank u soo much!Originally Posted by Trunk Monkey
IB (infinite baffle): - Hardly any space taken up and you can use 2 15's if you wanted.
- Easy install
- Cheap
ok quick question, the 10w3v3 has a 2ohm and 4ohm but both same wattage. which one is more efficient? i mean which ohm load is better for the amp?
I use one of Travis' enclosures and recommend it:
http://cgi.ebay.com/ebaymotors/Custo...fAudioQ5fVideo
I'm running a 10W3V3 in this enclosure (the 10" enclosure) and I have the 4 ohm version. In general the higher the speaker impedance the easier it is for your amp to drive the speaker; the lower the speaker impedance the louder or more output the speaker will produce (as long as the amp can drive the load).
No problem jdaddy. If you go with the side box, I'd definitely go with something other than a w3. Plenty of very nice 10's or 12's that will get plenty loud and sound damn good. I would have went that route first.
